Again problem with DclFMXTeePro916.bpl
martin-m
Post by martin-m » Fri Jun 08, 2012 5:54 pm
Hello Suppoert,
I just installed RadStudioXE2, Update 4, HotFix 1 and then TeeChartPro 2012 VCL Binary. Again the Problem with DclFMXTeePro916.bpl appears (... must be recompiled ...). Deinstallation and reinstallation does not help. That problem should have been fixed since the March release.
Also I still have a TeeChart Std Tool Palette and a TeeChart and TeeTree Palette (with the Pro components in) although no STF package is installed anymore.
TeeChart FireMonkey Components for iOS are enabled, for VCL are not.
Any ideas?
THX
Martin
rgsolutions
Re: Again problem with DclFMXTeePro916.bpl
Post by rgsolutions » Mon Jun 11, 2012 8:59 pm
I am having the same problem. I am running C++ XE2 update 3 (I could not run 4 as it had debugger issues).
The processing is also attempting to load DclFMITeePro916.bpl. I am not sure how all this hangs together, but I suspect it is is attempting to load the bpl for the iOS. It is possible that this is a separately priced item. If it is, then why is the processing try to load something that I have not purchased? If not, then where are the files?
Post by Yeray » Tue Jun 12, 2012 10:28 am
martin-m wrote:I just installed RadStudioXE2, Update 4, HotFix 1 and then TeeChartPro 2012 VCL Binary. Again the Problem with DclFMXTeePro916.bpl appears (... must be recompiled ...). Deinstallation and reinstallation does not help. That problem should have been fixed since the March release.
Any ideas?
rgsolutions wrote:I am having the same problem. I am running C++ XE2 update 3 (I could not run 4 as it had debugger issues).
Take a look at the explanation here:
http://www.teechart.net/support/viewtop ... 817#p56817
So, TeeChart v2012.05 supports XE2 Update 4, while TeeChart v2011.04 was compiled using XE2 Update 3.
It should work fine if you are using the installer according to your IDE version.
Please, check it again.
Post by Yeray » Wed Jun 13, 2012 1:04 pm
I'm afraid you were right. My apologies. The Hotfix for Update 4 in Rad XE2 has also changed something that makes DclFMXTeePro916.bpl to have to be recompiled. The version with TeeChart v2012.05 doesn't work in it.
We're preparing the installers and I hope we can publish the next v2012.06 before the end of the week.
If you are a source code customer, recompiling the sources with TeeRecompile tool should make it work too.
martin-m
Post by martin-m » Wed Jun 20, 2012 5:55 am
I'm not a source code customer but having a TeeChart VCL Pro subscription. Can I crossgrade from TeeChartProVCL to TeeChartProVCL with Source and if so what's the procedure therefore?
THX
Martin
Post by Marc » Fri Jun 22, 2012 2:15 pm
Hello Martin,
You can migrate the VCL Binary version to the Source version by contacting sales (sales@steema.com) who will give you a quote for the migration price.
Please note that the v2012.06 version mentioned in our previous post is now available for download.
