Can't load DclFMITeePro916.bpl
vlezhu
Post by vlezhu » Wed Mar 28, 2012 9:52 am
I've installed fresh RAD XE2 with preinstalled TeeStandard
After that I've installed new Tee2012Xe2 binary pack.
On RAD XE2 start I got error message: can't find fmi162.bpl, can't load DclFMITeePro916.bpl.
As I remember this is rather old error, why it exist for a new Tee2012Xe2 ?
Re: Can't load DclFMITeePro916.bpl
Post by Narcís » Wed Mar 28, 2012 10:16 am
Hi vlezhu,
This error message indicates that you have not installed RAD Studio XE2 Update 4. v2012.05.120327 requires XE2 update 4.
vlezhu
Post by vlezhu » Wed Mar 28, 2012 10:25 am
The second problem:
The $(TEEINCPATH) and $(TEELIBPATH) were created but not written to the Options->Delphi Options->Library
and Options->C++Options->Path and Directories->Include path and Library Path,
Also the $(TEELIBPATH)\Obj has to be added to the Delphi/Builder library paths.
I had to make these actions by hand.
vlezhu
Post by vlezhu » Wed Mar 28, 2012 10:26 am
No, you are not write, the Radxe2->About shows Update 4 for help and Rad
vlezhu
Post by vlezhu » Wed Mar 28, 2012 10:30 am
As concerned my first topic - the solution is to remove from Components pane the DclFMITee916, as for some reason it was note removed by installer and RAD tried to use both FMX components - Standard and Pro at the same time.
Post by Yeray » Fri Mar 30, 2012 7:22 am
Thanks for reporting it. We'll try to improve the installer both for the include/library paths and the packages uninstallation before the current installation.
