problem of "SaveToBitmapFile function"
sjsun116
Post by sjsun116 » Fri Mar 23, 2012 7:14 am
My software Teechart version is "Teechart Pro v2011.03.30407".
My application request to save a new chart as BMP file when a new point series or lin series was drawn in chart .But the BMP file saved using function "SaveToBitmapFile" is all the same. I don't know how to solve this problem ,very very urgent ! Who can help me,Thank you. I'd appreciate it.
Re: problem of "SaveToBitmapFile function"
Post by Narcís » Fri Mar 23, 2012 12:58 pm
Hi sjsun116,
Current version is v2011.04 and v2012.05 will be published very soon. You might be interested in testing the latest version.
What do you exactly mean with this, could you please provide more detailed information? A simple example project we can run "as-is" to reproduce the problem here would also be helpful.
sjsun116
Post by sjsun116 » Tue Mar 27, 2012 2:59 pm
Hi Narics,
Thank you.
A question:are these version compatible?
An example(BCB 6.0) such as:
AnsiString ToName;
DateSeparator = '-';
ShortDateFormat = "yyyy/mm/dd";
ToName = DateToStr(Date());
ShortDateFormat = "hh/mm/ss";
ToName = "2D-"+ToName+"-"+DateToStr(Time());
SaveDialog1->FileName = ToName;
if (SaveDialog1->Execute())
if (FileExists(SaveDialog1->FileName))
DeleteFile(SaveDialog1->FileName);
Chart1->SaveToBitmapFile(SaveDialog1->FileName);//chart1 is a Chart Unit
This example show how to capture and save the chart picture,when I draw line or point and so on in Chart1.
but I can't get the changed chart picture.
Post by Yeray » Wed Mar 28, 2012 2:38 pm
I'm not sure to understand the exact problem either.
I've added a Chart and a TLineSeries with some values at design time, in a new C++Builder application. I've also doped a Button to the form and then used your code just adding a point, and it seems to work fine for me here:
void __fastcall TForm1::Button1Click(TObject *Sender)
  Chart1->Series[0]->Add(100);
  AnsiString ToName;
  ToName = "2D-"+ToName+"-"+DateToStr(Time())+".bmp";
If you still have problems with it, please try to arrange a simpl example project we can run as-is to reproduce the problem here.
sjsun116
Post by sjsun116 » Tue Apr 03, 2012 4:18 pm
I upload a test file developed using C++builder 6.0. Please download three part and then decompress .
The test have three button:draw1,draw2 and ScreenShot.When you click the button "draw1" or the button "draw2",it will draw picture 1 or picture 2.
when you click the button "ScreenShot",it will capture the chart picture.
The problem :
when you click the button "ScreenShot" after "draw1",you will get the picture1.But afterwards you click the button "ScreenShot" after "draw2",you can't
get the picture2.
when you click the button "ScreenShot" after "draw2",you will get the picture2.But afterwards you click the button "ScreenShot" after "draw1",you can't
get the picture1.
How can I get the changed chart picture?
test.part01.rar
test file 01
(488.28 KiB) Downloaded 390 times
test.part02.rar
test file 02
(488.28 KiB) Downloaded 376 times
test.part03.rar
test file 03
(10.61 KiB) Downloaded 361 times
Post by Yeray » Wed Apr 04, 2012 9:50 am
Hi sjsun116,
I could reproduce it with v2011.03 but it seems to work fine in v2011.04 and the current v2012.05.
Could you please give it a try?
sjsun116
Post by sjsun116 » Fri Apr 06, 2012 2:08 am
OK,Thank you very much.
