Export and Themse
dpguest
Export and Themse
Post by dpguest » Thu Mar 15, 2012 7:33 pm
using D7, I drop a chart editor on a form hook it up.
When I double click on the editor I see the tabs for Export and Themes. under export, I see all the possible export formats.
However, when I run the application, I no longer see the Themes tab in the editor, and the export tab only shows 3 or so output options instead of the long list.
What units am I missing or properties do I need to set?
thank you very much...
have a nice day...
David Guest
Re: Export and Themse
Post by Yeray » Fri Mar 16, 2012 4:12 pm
Hi David,
This was discussed here and here
