follow up on TV52015812, Series with DateTime Axis Periodi
pch-chj
Post by pch-chj » Thu Mar 01, 2012 11:34 am
I were having a support session with Yeray Alonso 03 Nov 2011 12:45.
Yeray made a bugtracker ID (TV52015812).
I wondered where I can retrieve a fix for this issue? As I see the last time you released something for VCL was november last year.
Best regards Christian
I attach here the previous post:
(I have renewed my subscription and I received a new License number. So now im not authorized to post new messages to the original thread, that had another License number.)
Bug: Shape Series with DateTime Axis Periodicly disappears
Post a reply
2 posts • Page 1 of 1
by pch-chj » 02 Nov 2011 22:46
Version: TeeChart Pro v2011.03.30407 Win 32
We have a graph with an Rectangular Shape Series.
The X-axis is set to DateTime format.
The Shape ranges from year 1870's to 2100
The Axis is set to narrow range of 1 minute.
The Shape is only shown "sometimes" depending on the width.
The Timer1 changes the Width of the Chart2, showing how the
Shape disappears and re-appears by setting the width.
SteemaRectDisappears.zip
Example of the Bug.
(1.97 KiB) Downloaded 11 times
pch-chj
Top
Re: Bug: Shape Series with DateTime Axis Periodicly disappears
by Yeray » 03 Nov 2011 12:45
You are right. However, it seems to be related to the axis range and the chart size, independently of setting the axis as DateTime or not.
Here it is the code to reproduce it. You just have to resize the chart to see how the series appears and disappears.
CODE: SELECT ALL
uses TeeShape;
Chart1.Align:=alClient;
Chart1.View3D:=false;
with Chart1.AddSeries(TChartShape) as TChartShape do
Style:=chasRectangle;
Chart1.Axes.Bottom.SetMinMax(99.99999, 100);
I've added it to the defect list to be revised for future releases (TV52015812).
Thanks for reporting it.
Best Regards
Yeray Alonso
Steema Support Central
Steema Support Forums
Follow us in Twitter and Facebook
Re: follow up on TV52015812, Series with DateTime Axis Periodi
Post by Yeray » Fri Mar 02, 2012 3:05 pm
Hi Christian,
pch-chj wrote:I were having a support session with Yeray Alonso 03 Nov 2011 12:45.
I'm afraid the TV52015812 hasn't been fixed yet.
I recommend you to be aware at the following channels for new release announcements and what's implemented on them:
- Support forum.
- RSS news feed
- Twitter
- Facebook
pch-chj wrote:I have renewed my subscription and I received a new License number. So now im not authorized to post new messages to the original thread, that had another License number.
You can't post a reply in the original thread, but you can open a new one?
I've tried to login with your new license and password, and it seems to work fine for me here. I can see the "Post a reply" button, and it seems to work.
pch-chj
Post by pch-chj » Mon Mar 05, 2012 8:59 am
Is there a work around at this moment I could use? (I have the Tee source code)
2.
Can you say when an update is available? (Im receiving your RSS feeds)
ps:
Yes I can work with my "new license number".
But its a bit strange that my posting made with "previous license number" is now unavailable.
It means I loose easy access to my previous postings each time I renew the subscription (every year).
Post by Yeray » Tue Mar 06, 2012 3:39 pm
Hi Christian,
pch-chj wrote:1.
I've taken a look at it but I'm afraid I can't think on a workaround for it.
pch-chj wrote:2.
I'm afraid not. I hope it could be soon.
pch-chj wrote:ps:
Right. We'll study if it's possible to allow posting with the old license info to those who have renewed the subscription.
pch-chj
Post by pch-chj » Wed Mar 07, 2012 9:47 am
Ok.
We have purchased the chart products since 2009.
And now we have all our 3rd party components on XE2.
However it is impossible for us to make the upgrade to XE2, because we need this fix (our product is useless without this fix).
Now we waited since november for the fix, almost half a year.
I think at least a work-around should be made, that we can use temporarily until your next release.
Alternatively, the optimal would be that you could make an official release very very soon.
Post by Narcís » Wed Mar 07, 2012 3:05 pm
Hi Christian,
The smallest code snippet Yeray found to reproduce the issue here is this:
uses TeeShape;
This seems to be an internal rounding issue and found that setting bottom axis minimum value to 99.9999 (one decimal digit less than the snippet above) works fine for us. Considering you came across this issue with DateTime values this would leave you with an accuracy of a 1/10000 of a day. This is almost 1/7h of a minute, about 8.5 seconds, 9 for good measure. Would this accuracy be acceptable for you? Can you please check if this solves the problem for you?
uses TeeShape;
  Chart1.Axes.Bottom.SetMinMax(99.9999, 100);
pch-chj
Post by pch-chj » Fri Mar 09, 2012 2:06 pm
Hi Narcís,
We need 4 horizontal filled shapes on-top-of-each other "ranging for all times" (this is the only way we know to implement it in TeeChart), maybe there is a better way?
I attach my original example.
Here we have 1 filled shape ranging from 1870's to 2100.
Now we may zoom to 1 second of information. So a big range, compared to very small zoomed range.
When you run it, you will see it flickers.
What is the max date range we can have while we can zoom to 1 second?
(1.97 KiB) Downloaded 300 times
Post by Narcís » Fri Mar 09, 2012 3:58 pm
Hello Christian,
Thanks for your feedback. I think I have found the problem using your example. At TeEngine.pas, in the TChartAxis.XPosValueCheck, when the first point in the shape is being painted, IStartPos+Round(tmp) exceeds the lower range of Integer values in Delphi and hence result is absolutely wrong. Implementing XPosValueCheck as shown below solves the issue. I don't think this is the right solution considering TeEngine.pas is on of the core units in TeeChart. We will need to investigate the issue further to find the proper solution. In the meantime, can you please check if this works fine at your end?
Function TChartAxis.XPosValueCheck(Const Value:TChartValue):Integer;
var tmp : Double;
    tmp2: Int64;
  if IRangeZero then result:=ICenterPos
    tmp:=(Value-IMinimum)*IAxisSizeRange;
    if IUseTeeMaxPixelPos then
      if FInverted then tmp:=IEndPos-tmp
                   else tmp:=IStartPos+tmp;
      if tmp> TeeMaxPixelPos then result:=TeeMaxPixelPos
      if tmp<-TeeMaxPixelPos then result:=-TeeMaxPixelPos
         result:=Round(tmp);
    end
    if FInverted then result:=IEndPos-Round(tmp)
                  tmp2:=IStartPos+Round(tmp);
                  result:=Max(tmp2,Low(Integer));
I'll get back to you when we have further news.
pch-chj
Post by pch-chj » Fri Mar 09, 2012 4:58 pm
Hi Narcís,
ok now we are moving forward :)
1.
Your fix has solved the problem I gave you.
But now I attach a small extension to the test program that shows there are still flickering.
2.
I hope you can hunt it down pretty much yourself now, because it is very time consuming to first uninstall my working "v. 8.06" then install "v. 2011".
Actually have you tried it yourself? It is impossible to do with your installers to first uninstall v. 8.06 and then install v. 2011 (I get some error message "AUTO" Failed).
It is required by me to go and find the v. 2011 bpl's myself and add DclTeePro914.bpl manually in Delphi 2010!! And then it is also required by me to Add Search paths!!!
I use Windows 7, 64bit.
SteemaRectDisappears2.zip
(2.08 KiB) Downloaded 278 times
Post by Narcís » Mon Mar 12, 2012 10:25 am
Hi Christian,
1.
Ok, implementing the mentioned method as shown below works fine for both cases
var tmp : Double;
    tmp2: Int64;
         result:=Round(tmp);
    end
                  if tmp2 > High(Integer) then
                    result:=High(Integer)
Can you please check it at your end?
2.
Are you using TeeInstall.exe shipped with the binary installers? Actually, being a source code customer, probably the easier solution is using the Recompile tool included with the source code installers.
Post by Narcís » Mon Mar 12, 2012 12:28 pm
Hi Christian,
After some more investigation we think the solution to such corner cases is a TeeChart built-in mechanism:
type
  TAxisAccess=class(TChartAxis);
  TAxisAccess(Chart2.Axes.Bottom).IUseTeeMaxPixelPos:=True;
Find attached your first project with those changes. I tested it works fine for both projects you sent. Can you please check if this solves the problem at your end?
It's important to leave TeEngine.pas as it is as Calc* methods are crucial for good performance when having lots of data in a chart. We will consider moving this mechanism to a public property, for example:
Chart2.Axes.Bottom.CheckLimits:=True;
(3.08 KiB) Downloaded 292 times
pch-chj
Post by pch-chj » Mon Mar 12, 2012 3:01 pm
Hi Narcís ,
1.
yes!
Now it seems to work with this very nice simple change.
The switch we set to True, does it mean that the chart will be slower for large datasets?
2.
Also: Is there a nice switch or similar that can let the TChartShape paint behind the chart Grid?
3.
In regards to installation of your TeeChart components: I imagine it will be most optimal for all parties if I can run the installer TeeChart2011Delphi2010.exe and
TeeChart2010SourceCode.exe
and also I can un-install the components by the installers.
When I start Delphi the next time "it just works". (this is what Developer Express and EurekaLog does and even NexusDB )
Post by Narcís » Mon Mar 12, 2012 4:04 pm
Hi Christian,
1.
yes!
Excellent! It may slow down your application a little bit but if I'm not wrong that switch was to prevent Win 95/98 16-bit GDI related issues. You should test with your projects if data is big enough to notice any difference.
2.
Yes, you can use Axes.Behind property:
  Chart1.Axes.Behind:=False;
3.
Aha, I see. Other users like to keep old version installed and switch across version. This could be something to choose during the installation process. I'll add it to the wish-list to be considered for inclusion in future releases.
