Dragging TColorBand
Metman
Dragging TColorBand
Post by Metman » Wed Feb 22, 2012 4:03 pm
Just a simple question - is it possible to drag a TColorBand?
I realize if the color band has been attached to a horizontal axis then either end of the color band be expanded/contracted. What I would like to do is drag the area horizontally across the chart without changing the extent of the band.
Bruce.
Re: Dragging TColorBand
Post by Yeray » Thu Feb 23, 2012 5:33 pm
Hi Bruce,
You can drag the start and end lines as below:
uses Series, TeeTools;
  Chart1.View3D:=false;
  Chart1.AddSeries(TFastLineSeries).FillSampleValues();
  with Chart1.Tools.Add(TColorBandTool) as TColorBandTool do
    Axis:=Chart1.Axes.Bottom;
    StartValue:=5;
    EndValue:=15;
    ResizeStart:=true;
    ResizeEnd:=true;
If you want to move both lines at the same time when clicking Down between the two lines and dragging, you could use the OnMouseDown, OnMouseUp and OnMouseMove event to do it manually.
Metman
Post by Metman » Mon Feb 27, 2012 3:52 pm
Hi Yeray
Thanks for the tip - I did what you suggested and I can now control the bands with the mouse.
Bruce.
Post by Yeray » Tue Feb 28, 2012 4:06 pm
Hi Bruce,
Great! I'm glad to hear it works as you want now. :)
