Activate TeePro extensions in my app.
H.Hasenack
Post by H.Hasenack » Tue Feb 14, 2012 2:38 pm
My app uses runtime libraries, and also depends on the teepro extensions. Unfortunately the initialization section of the units are not called if they are not in the uses list of the main app, or if no code from the unit is directly linked into my own units.
Is there an 'easy' way to ensure all "pro" extensions are activated? I can do this by calling LoadPackage('Teepro916.bpl'), or by adding all pro units to tot uses list of the main app.
Any other useful tips?
Regards - Hans
Re: Activate TeePro extensions in my app.
Post by Yeray » Fri Feb 17, 2012 4:06 pm
Hi Hans,
Excuse us for the delay here.
We haven' forgotten you and we'll be back to you asap.
Post by Narcís » Mon Feb 20, 2012 10:17 am
Hi Hans,
What about adding TeeEditPro unit to your uses section? Which exact problem do you have? Any specific unit missing?
H.Hasenack
Post by H.Hasenack » Tue Feb 28, 2012 8:38 am
My app uses a plugin system for extenstions. These plugins are simply runtime packages that are in a subfolder and loaded during runtime.
In order to do this I have a kernel bpl and a very minimalistic exe file that depends only on some vcl runtime libs and the kernel bpl.
The kernel itself depends on the tchart libs, but does not require the tchart pro extensions.
Nevertheless, our end users want to use some of the pro features. But the pro features are not visible because the initialization sections of the corresponding packages are not executed when they are not explicitely mentioned in the exe uses list.
so: the problem is : I cannot see the tchartpro extensions in my tchart editor, only the tchart basic functionality
mycurrent solution now is a routine that scans all loaded bpl's and ensures all units are initialized like this:
procedure InitializePackages(VAR aPackageList:THandleList);
  function lclInPackageList(const aHandle:Thandle):boolean;
    Result:=Assigned(aPackageList) and (aPackageList.IndexOf(aHandle)>=0)
  function lclIsPackage(aHandle:THandle):boolean;
    Result:=(aHandle<>0)
            and (GetProcAddress(aHandle, 'Initialize')<>nil)
            and (GetProcAddress(aHandle, 'Finalize')<>nil);
VAR Module:PLibModule;
  Module := LibModuleList;
  while Module <> nil do
    if (Module.Instance<>0)
       and not lclInPackageList(Module.Instance)
       and lclIsPackage(Module.Instance) then
      if aPackageList=nil then
        aPackageList:=THandleList.Create;
      try
        InitializePackage(Module.Instance);
        aPackageList.Add(Module.Instance);
      except
        raise EModuleListError.CreateFmt('InitializePackages failed for [%s]',[ModuleFileName(Module.Instance)]);
    Module:=Module.Next;
(off course there is also a counterpart for this)
Should adding TeeEditPro to my uses list (preferably only in my kernel.bpl) add/register all pro features? - Using XE2
(I was delayed a bit too - I had a one-week holiday )
Regards - Hans
Post by Yeray » Thu Mar 01, 2012 3:19 pm
Hi Hans,
As you'll see, the Pro classes are registered in the beginning of TeeEdiPro.pas. Isn't adding that unit to you uses clause solving the issue for you?
