TestAlways
- Advanced
Post
by TestAlways » Tue Jan 31, 2012 5:52 pm
In previous versions, I used Method 1 below without fail. But in moving to the latest version, it doesn't work. I did some testing and Method 2 works fine:
//Method 1
lChart.Draw(aRG.Bitmap.Canvas, lRect);
CodeSite.Send('Batch Gap Chart', aRG.Bitmap); // <--- this is blank
//Method 2
lBmp := lChart.TeeCreateBitmap(clWhite, lRect);
try
aRG.Bitmap.Assign(lBmp);
CodeSite.Send('Chart Bitmap', lBmp);
finally
lBmp.Free;
I implemented Method 1 in a demo application and it worked fine. Any reason it might not be working?
Post
by Yeray » Wed Feb 01, 2012 12:11 pm
Hi Ed,
I'm trying the following in a new simple application with just a chart and two TImage in the form, and everything works as expected in the actual version, doesn't it for you?
Chart1.AddSeries(TBarSeries).FillSampleValues();
Chart1.Draw(Image1.Canvas, Chart1.ClientRect);
Image2.Picture.Bitmap.Assign(Chart1.TeeCreateBitmap(clWhite, Chart1.ClientRect));
TestAlways
- Advanced
Post
by TestAlways » Wed Feb 01, 2012 4:28 pm
It works in my demo, but it did not work in my application. I cannot tell you why.
Post
by Yeray » Thu Feb 02, 2012 10:04 am
Hi Ed,
There were some changes in the drawing process in the last releases:
http://www.teechart.net/support/viewtop ... 438#p49438
So I wouldn't discard the possibility that some related functions may have been affected.
If you find an easy way to reproduce it consistently so we can reproduce, debug,... it here, we'll be pleased to take a deeper look at it.
