X Axis values overwrite
TestAlways
Post by TestAlways » Tue Jan 17, 2012 4:41 pm
On my development computer, I am using 2011.03.30407 and the footer to a chart appears fine:
but on the build server, I have 2011.04.41118 installed and the footer values overwrite each other:
It's the exact same code, just different version of TChart.
Is there a fix for this?
Ed Dressel
Re: X Axis values overwrite
Post by Yeray » Thu Jan 19, 2012 11:46 am
Hi Ed,
I've been testing this and found that the axis labels behaviour has changed several times in v2010-2011 when you have two series with labels.
There are two problems that seem to be related because in the releases where the first problem is reproducible, the second isn't. And viceversa.
//Problem #1
uses Series;
var i: Integer;
  Chart1.View3D:=false;
  Chart1.AddSeries(TFastLineSeries);
  for i:=0 to 49 do
    Chart1[0].AddXY(i, random, IntToStr(Chart1[0].Count));
    if i mod 5 = 0 then
      Chart1[1].AddXY(i+0.2, random, IntToStr(Chart1[1].Count));
//Problem #2
uses Series;
  Chart1[0].AddXY(1, 2, 'test1');
  Chart1[0].AddXY(2, 3, 'test2');
  Chart1[1].AddXY(0, 2, 'test0');
  Chart1[1].AddXY(1, 3, 'test3');
I've added it to the defect list to be revised asap (TV52016009).
TestAlways
Post by TestAlways » Thu Jan 19, 2012 4:29 pm
Thanks for the response.
This seems pretty significant to me. I have access to the source. Does Steema provide hot fixes/patches for the source?
Thank you,
Ed Dressel
Post by Yeray » Fri Jan 20, 2012 2:21 pm
Hi Ed,
You could comment a for loop in the Procedure AxisLabelsSeries; nested in the Procedure TChartAxis.Draw(CalcPosAxis:Boolean);
for s:=0 to ISeriesList.Count-1 do
This will make the Problem #1 to be solved, but note the problem #2 will then appear again.
TestAlways
Post by TestAlways » Fri Jan 20, 2012 11:06 pm
Does Steema provide hotfixes for bugs?
Post by Yeray » Mon Jan 23, 2012 8:34 am
Hi Ed,
Usually not. Only if we find a bug is enough critical to justify it we can prepare new installers.
But being source code customer, the explanation of the modification above should be enough, isn't it? We can also send the affected files if the customer interested has the sources.
TestAlways
Post by TestAlways » Mon Jan 30, 2012 3:35 pm
Yeray wrote:Usually not. Only if we find a bug is enough critical to justify it we can prepare new installers.
How does a bug, such as this, rank where the X axis is non-readable?
Yeray wrote:But being source code customer, the explanation of the modification above should be enough, isn't it? We can also send the affected files if the customer interested has the sources.
For me to modify your source would mean I would have to get an understanding of your source--I really don't have time for that. I would much prefer showing me which unit(s) and method(s) need to be modified and how.
Post by Yeray » Tue Jan 31, 2012 11:07 am
Hi Ed,
TestAlways wrote:How does a bug, such as this, rank where the X axis is non-readable?
I've added it as "Serious" so its priority in quite high in the list but the time until we can fix it also depends on other variables such as the complexity of the problem, the study of the possible collateral damages, the number of issues with even higher priority that claims our team attention,...
I recommend you to be aware at this forum, our RSS news feed, twitter and facebook accounts for new release announcements and what's implemented on them.
TestAlways wrote:For me to modify your source would mean I would have to get an understanding of your source--I really don't have time for that. I would much prefer showing me which unit(s) and method(s) need to be modified and how.
Excuse me if my previous reply wasn't detailed enough.
In the TeEngine.pas shipped with the v2011.04, the line to comment/remove is the line number 5450 that should be a for entry:
