AxisScroll Tool triggers OnZoom
rvc
Post by rvc » Thu Jan 12, 2012 2:06 pm
I added an AxisScroll tool for the bottom Axis, but this triggers Onzoom event. Is this meant to be? I would expect OnScroll to be triggered instead...
Regards, Ronald
Re: AxisScroll Tool triggers OnZoom
Post by Yeray » Fri Jan 13, 2012 9:34 am
Hi Ronald,
Are you using the latest version? The following example works as expected for me here.
May I be missing some relevant setting?
uses TeeTools, Series;
  Chart1.View3D:=false;
  Chart1.AddSeries(TLineSeries).FillSampleValues;
  (Chart1.Tools.Add(TAxisScrollTool) as TAxisScrollTool).Axis:=Chart1.Axes.Bottom;
  ShowMessage('OnZoom');
procedure TForm1.Chart1Scroll(Sender: TObject);
  ShowMessage('OnScroll');
