Wrong X Axis displayed when legend has checkboxes
rloewy
Post by rloewy » Sun Jan 08, 2012 7:41 pm
I have a strange issue:
I have a chart with 2 series, and the legend has checkboxes.
When I display the chart with the normal stuff - the X-Axis is just fine.
If I uncheck both series, and then check again one of the series - the X-Axis loses it's normal formatting and shows the internal data-value of the X-Axis instead of my pre-defined x-axis values.
Any ideas?
Re: Wrong X Axis displayed when legend has checkboxes
Post by Yeray » Mon Jan 09, 2012 2:37 pm
I'm trying to reproduce the problem with the following code but it shows the same labels in the bottom axis all the time:
uses Series;
  Chart1.Legend.CheckBoxes:=true;
  Chart1.AddSeries(TPointSeries).FillSampleValues();
  with Chart1.Axes.Bottom.Items do
    Clear;
    Add(0, '0');
    Add(2, '2');
    Add(5, '5');
    Add(8, '8');
    Add(9, '9');
    Add(15, '15');
    Add(19, '19');
    Add(24, '24');
rloewy wrote:instead of my pre-defined x-axis values
The clue will probably be on how are you defining these labels.
If you still have problems with it, please, try to arrange a simple example project we can run as-is to reproduce the problem here.
