Friis
- Newbie
Post
by Friis » Sun Jan 01, 2012 7:38 pm
I'm using a OnClickSeries on a GanttSeries.
How do I obtain the MarkText when I click on a TGantt series?
I have tried the following but it doesn't work:
procedure TForm1.Chart14ClickSeries(Sender: TCustomChart; Series: TChartSeries;
ValueIndex: Integer; Button: TMouseButton; Shift: TShiftState; X, Y: Integer);
GanttSeries : TGanttSeries;
if Series is TGanttSeries then
GanttSeries := Series as TGanttSeries;
showmessage(GanttSeries.Marks.Item[valueindex].Text[0]);
Post
by Yeray » Wed Jan 04, 2012 9:17 am
Hi Friis,
If in the Marks you are showing the Labels, you can simply show the Labels in the click event:
ShowMessage(GanttSeries.Labels[ValueIndex]);
If you are using a different Marks Style, you'll have to format your string manually, but knowing the ValueIndex of the point, it shouldn't be difficult. Anyway, if you find any problem with it, don't hesitate to let us know.
