TTeeXMLSource Y-axis values
rvc
Post by rvc » Tue Dec 27, 2011 8:43 pm
My XML contains values with point (.) as decimal separator. my PC uses colon (') as decilamseparator. this makes my PC think that value 22,000, which should be interpreted as 22, is interpreted as 22000. I tried setting Formatsettings.decimalseparator to point, which did not help.
What is the recommended way to make sure values are interpreted correctly?
Regards, Ronald
Re: TTeeXMLSource Y-axis values
Post by Yeray » Wed Dec 28, 2011 10:06 am
Hi Ronald,
Try setting a different ThousandSeparator too. If 22,000 is taken as 22000 it's probably because the ThousandSeparator is ','. So you could try this:
  ThousandSeparator:='.';
  DecimalSeparator:=',';
