Installing helpfiles in Delphi XE
rvc
Post by rvc » Mon Dec 26, 2011 1:51 pm
I downloaded the helpfiles for 2010 VCL as zip, but the do not show up in Delphi XE's help. So, now I do noet have any help at all. Anyone whow knows how to install the helpfiles?
Regards, Ronald
Re: Installing helpfiles in Delphi XE
Post by Yeray » Tue Dec 27, 2011 9:59 am
Hi Ronald,
What zip have you exactly downloaded?
Note the TeeChart installation already tries to install the documentation into the IDE (not for the oldest IDEs). The installation should contain a "\Docs\RADStudio" folder with the necessary files for it. If the installer failed to do it automatically, you could try to follow the instructions in the Readme.txt in that folder to install the documentation manually into the IDE.
rvc
Post by rvc » Tue Dec 27, 2011 11:31 am
Hello Yeray,
I installed teechart from TeeChart2011SourceCode.exe, but found no reference to help files. Then I downloaded VCL 2010 Help (zipfile from your website) and executed installHelpToRADStudioXE.bat. Still no help.
Please advise.
Regards, Ronald
Post by Yeray » Tue Dec 27, 2011 12:41 pm
Hello Ronald,
We recommend to the source code customers to install the binary version prior to the source code version since only the first one includes the documentation and the examples. The binary installers should also be listed in your client area.
rvc
Post by rvc » Tue Dec 27, 2011 1:11 pm
Installing the binaries did the trick!
Thanks, Ronald
Post by Yeray » Tue Dec 27, 2011 2:05 pm
Hi Ronald,
Great! :D
