TeeChart 2011.04 Pro With Source Code installation fails
Posted: Mon Nov 21, 2011 12:13 pm
by 16560688
Installation for Delphi 2010 succeeds :
TeeChart Installation
VERSION: 2011
RAD 2010.Win32 v14 Architect (Delphi and C++Builder 2010 Update 5 (Database Pack)) (RAD v7 Architect) (C++)
OK. Time: 9s
But it fails for XE2 Update 2 :
RAD XE2.Win32 v16 (RAD XE v9 Enterprise) (C++)
EXCEPTION:
Text: unit teeGDIPAPI not found in teeGDIPAPI.pas
Note that it still find very strange that TeeRecompile.exe don't see "Delphi" compilers for All RAD XE2 entries, it only shows :
RAD XE2.Win32 c 16 (RAD XE v9 Entreprise) (
C++)
where it shows for Delphi 2010 :
RAD 2010.Win32 v 14 Architect (
Delphi and C++Builder 2010)
Re: TeeChart 2011.04 Pro With Source Code installation fails
Posted: Tue Nov 22, 2011 10:05 am
by narcis
Hi Pierre,
EXCEPTION:
Are you using the latest 2011.04.41118 build we published yesterday?
RAD XE2.Win32 c 16 (RAD XE v9 Entreprise) (C++)
It works fine for me here, do you have full RAD XE2 installed at your machine? Does this also occur with yesterday's release?
Posted: Tue Nov 22, 2011 2:08 pm
by 16560688
NarcĂs wrote:Are you using the latest 2011.04.41118 build we published yesterday?
Yes. I installed the 2011.04.41118 SourceCode version from november, 17th
This is in the Release.txt file :
Release Notes 17th November 2011
TeeChart VCL version 2011
Build 2011.04.41118
Posted: Wed Nov 23, 2011 9:05 am
Hi Pierre,
Could you please also tell us if you have full RAD XE2 installed at your machine?
TeeRecompile usually shows 4 entries for XE2 (Win32, Win64, MacOSX and iOS). If TeeRecompile only shows one entry it may be finding just one of the personalities.
Posted: Wed Nov 23, 2011 2:19 pm
by 16560688
Yes RAD Studio XE2 is fully installed with all personalities. I installed French and English languages.
TeeRecompile shows 4 entries but between parenthesis, at the end of the compiler line, it only shows (C++) (see attached screenshot)
- Screenshot of TeeRecompile on my machine.
- tee_recompile.png (55.69 KiB) Viewed 16416 times
Posted: Wed Nov 23, 2011 4:33 pm
Hello Pierre,
The "(C++)" in the string that identifies the IDE is normal. It just indicates that the IDE has a C++ personality. It's also in the RAD2010 checkbox but this string is so long that it's partially hidden. The RADXE2 strings is one of the things we want to clean for the next maintenance releases.
However, as you can see in my screenshot, it works fine for me here.
- TeeRecompile.png (51.89 KiB) Viewed 16427 times
I'm not sure about what can be happening here. We'll continue investigating it.
Posted: Thu Nov 24, 2011 3:57 pm
by 16560688
I reinstalled Teechart Pro 2011 "Source Code" from scratch. And checked only the RAD Studio XE2 checkboxes in TeeRecompile and it worked. I don't know why I didn't worked with my first installation.
Sorry for the inconvenience and thank you for your patience. Regards,
Posted: Thu Nov 24, 2011 6:14 pm
by 16560688
I reproduced the problem and I found the fix !
Don't ask me why because I installed Teechart on a Windows 7 machine using NTFS file system and AFAIK Windows if not case sensitive, but, to fix the problem I have had to uppercase the first letter of TeeGDIAPI.pas and TeeGDIOBJ.pas... They were lowercased : teeGDIAPI.pas and teeGDIOBJ.pas !
Now it works everytime I run TeeRecompile.exe... This world becomes stranger and stranger...
Posted: Fri Nov 25, 2011 11:34 am
Bonjour Pierre,
Pierre Yager wrote:Don't ask me why because I installed Teechart on a Windows 7 machine using NTFS file system and AFAIK Windows if not case sensitive, but, to fix the problem I have had to uppercase the first letter of TeeGDIAPI.pas and TeeGDIOBJ.pas... They were lowercased : teeGDIAPI.pas and teeGDIOBJ.pas !
My installation is on the same environment (NTFS Win7 x64)... Wait! TeeGDIAPI.pas and TeeGDIOBJ.pas were already uppercase in my TeeChart v2011.04 SourceCode installation. So, if we find why they became lowerecase for you we'll find the origin of the problem. Anyway, I'm glad to hear you found it!
Pierre Yager wrote:This world becomes stranger and stranger...
+1
