Gantt Chart
TVD Support
Gantt Chart
Post by TVD Support » Wed Nov 09, 2011 9:22 pm
I have a requirement to plot value from one field against datetime. The Field value will be 1 or 0. I need to plot when the field value is 1 and then only when the field value is 0. I want to connect these points with a line.
Can this be done using a gantt chart? If not what other series type can i use?
TVD Support
Re: Gantt Chart
Post by TVD Support » Wed Nov 09, 2011 10:16 pm
Please find attached a sample on how I want the graph. The points named Ignition, TwistLock and Geforce are what I am trying to achieve
Re: Gantt Chart
Post by Yeray » Thu Nov 10, 2011 3:42 pm
I can't see any attachment. Did you forget submitting it?
