XE2 - Compiler Fatal Error
Gregg
Post by Gregg » Sun Nov 06, 2011 10:45 pm
I receiving the following error:
'[DCC Fatal Error] pc_map.pas(28): F2051 Unit VCLTee.TeeSurfa was compiled with a different version of VCLTee.Chart.TCustomChart'
I thought it may have had something to do with FastReport, as I had a problem earlier with c:\windows\system32\frxTee16.bpl . However, I have now recompiled FastReport against TeeChart Pro 9 so that shouldn't be the problem.
Any ideas.
Kind regards
Gregg
Gregg
Re: XE2 - Compiler Fatal Error
Post by Gregg » Sun Nov 06, 2011 10:50 pm
Re: The previous post.
The problem only occurs when compiling 64 bit, so the problem may be related to FastReports as I didn't recompile the 64 bit version.
Sorry about that.
Gregg
Post by Yeray » Mon Nov 07, 2011 9:47 am
Hello Gregg,
Gregg wrote:The problem only occurs when compiling 64 bit, so the problem may be related to FastReports as I didn't recompile the 64 bit version.
It would be great if you could confirm the cause of the problem was it, if possible.
Check also the library paths for all the platforms.
Gregg
Post by Gregg » Mon Nov 07, 2011 12:52 pm
I tried to compile the TeeMaps example. 32 bit no problem!
Compiling the 64 bit version produces the following error:
[DCC Fatal Error] UnitTestSHP.pas(22): F2051 Unit VCLTee.TeeSurfa was compiled with a different version of VCLTee.Chart.TCustomChart
I've disabled the FastReport packages - no difference.
The other third party packages I have installed are:
Devart - dbFusion (MySQL)
Devart - MySQL components
Raize Components Version 6
TMSSoftware Component Pack
DBISAM
ElevateDB
as far as I am aware none of the above use TeeChart.
Hope this helps
Kind regards
Gregg
Gregg
Re: XE2 - Compiler Fatal Error - Fixed
Post by Gregg » Mon Nov 07, 2011 2:49 pm
It appears the error was related to FastReport. I moved the steema path ahead of the fastreport path in the Library paths and that appeared to solve the problem.
So it's fixed now, sorry to have bothered you.
Kind regards
Gregg
Post by Yeray » Mon Nov 07, 2011 3:52 pm
Hi Gregg,
No worries. I'm glad to hear you solved it!
