Delphi XE2 Update1: Lot of hints in TeeChart units
Tom
Post by Tom » Fri Oct 28, 2011 11:53 am
Hello
I get a lot of hints for teechart units (2011.04.41003 Beta)
Could you remove this hints in the next (final) release?
Best regards
Tom
[DCC Hint] VCLTee.TeeVolEd.pas(78): H2443 Inline function 'TPen.GetColor' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeePolarEditor.pas(148): H2443 Inline function 'TPen.GetColor' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeeErrBarEd.pas(97): H2443 Inline function 'TPen.GetColor' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.MyPoint.pas(121): H2443 Inline function 'TTeeCanvas.AssignVisiblePen' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.MyPoint.pas(208): H2443 Inline function 'TTeeCanvas.AssignVisiblePen' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeeBoxPlot.pas(467): H2443 Inline function 'TBrush.GetColor' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeeBoxPlot.pas(475): H2443 Inline function 'TTeeCanvas.AssignVisiblePen' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeeBoxPlot.pas(495): H2443 Inline function 'TTeeCanvas.AssignVisiblePen' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeePageNumTool.pas(208): H2443 Inline function 'TTeeCanvas.AssignVisiblePen' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeeGridBandToolEdit.pas(105): H2443 Inline function 'TBrush.GetColor' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeeGridBandToolEdit.pas(119): H2443 Inline function 'TBrush.GetColor' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeeGauges.pas(182): H2443 Inline function 'TTeeCanvas.AssignVisiblePen' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeeGauges.pas(271): H2443 Inline function 'TTeeCanvas.AssignVisiblePen' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeeGauges.pas(334): H2443 Inline function 'TTeeCanvas.AssignVisiblePen' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeeGauges.pas(422): H2443 Inline function 'TTeeCanvas.AssignVisiblePen' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeeVectorEdit.pas(75): H2443 Inline function 'TPen.GetColor' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeeVectorEdit.pas(76): H2443 Inline function 'TPen.GetColor' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeePieTool.pas(123): H2443 Inline function 'TPen.GetColor' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeePieTool.pas(124): H2443 Inline function 'TPen.GetColor' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeePieTool.pas(125): H2443 Inline function 'TPen.GetColor' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeeSeriesBandTool.pas(250): H2443 Inline function 'TTeeCanvas.AssignVisiblePen' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeeSeriesBandTool.pas(377): H2443 Inline function 'TTeeCanvas.AssignBrush' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeeFrameTool.pas(192): H2443 Inline function 'TTeeCanvas.AssignBrush' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeeFrameTool.pas(199): H2443 Inline function 'TTeeCanvas.AssignVisiblePen' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeeText3D.pas(325): H2443 Inline function 'TTeeCanvas.AssignBrush' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeeText3D.pas(359): H2443 Inline function 'TTeeCanvas.AssignBrush' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeeText3D.pas(360): H2443 Inline function 'TTeeCanvas.AssignVisiblePen' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeeText3D.pas(369): H2443 Inline function 'TBrush.GetColor' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeeText3D.pas(574): H2443 Inline function 'TTeeCanvas.AssignVisiblePen' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeeMagnifyTool.pas(254): H2443 Inline function 'TTeeCanvas.AssignVisiblePen' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeeFibonacci.pas(336): H2443 Inline function 'TTeeCanvas.AssignVisiblePen' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeeFibonacci.pas(412): H2443 Inline function 'TTeeCanvas.AssignVisiblePen' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeeArrowTool.pas(250): H2443 Inline function 'TTeeCanvas.AssignVisiblePen' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeeArrowTool.pas(251): H2443 Inline function 'TTeeCanvas.AssignBrush' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeeTernaryEdit.pas(105): H2443 Inline function 'TPen.GetColor' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeeAxisBreaks.pas(315): H2443 Inline function 'TTeeCanvas.AssignVisiblePen' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeeAxisBreaks.pas(339): H2443 Inline function 'TTeeCanvas.AssignVisiblePen' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeeAxisBreaks.pas(454): H2443 Inline function 'TTeeCanvas.AssignBrush' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeeAxisBreaks.pas(557): H2443 Inline function 'TTeeCanvas.AssignBrush' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeeAxisBreaks.pas(585): H2443 Inline function 'TTeeCanvas.AssignBrush' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeeAxisBreaks.pas(604): H2443 Inline function 'TTeeCanvas.AssignBrush' has not been expanded because unit 'System.UITypes' is not specified in USES list
[DCC Hint] VCLTee.TeeAxisBreaks.pas(620): H2443 Inline function 'TTeeCanvas.AssignVisiblePen' has not been expanded because unit 'System.UITypes' is not specified in USES list
Re: Delphi XE2 Update1: Lot of hints in TeeChart units
Post by Yeray » Mon Oct 31, 2011 12:37 pm
Hello Tom,
We'll try to clean it. Thank you for reporting it.
