Regarding TPointSeries, changing to Single from Double
Johan Ingemansson
Post by Johan Ingemansson » Tue Sep 07, 2004 2:03 pm
Is it possible to change TChartValues from double to single. It would be excellent because the memory reduction would be about 50%.
Johan Ingemansson
Marjan
Post by Marjan » Tue Sep 07, 2004 3:15 pm
Hi.
Yes, it can be done, but only if you have TeeChart source code. If you have, then all you must do is open the TeeDefs.inc file and locate the following lines:
/ "Value" type for point values data.
// Remove the "." on ONLY one of the items below:
{$DEFINE TEEVALUEDOUBLE}
{.$DEFINE TEEVALUESINGLE}
{.$DEFINE TEEVALUEEXTENDED}
and change them to
{.$DEFINE TEEVALUEDOUBLE}
{$DEFINE TEEVALUESINGLE}
Then recompile and reinstall all TeeChart packages.
Marjan Slatinek,
Johan Ingemansson
Possible for adjustment
Post by Johan Ingemansson » Wed Sep 08, 2004 6:13 am
So if I don´t have the source code then it´s impossible? Wouldn´t it be possible for Steema to make this adjustment, since I would benifit greatly for the reduced memory consumtion. I would be forever gratefule. If this isn´t possible I would recommend that this feature is standard in next coming versions of TeeChart.
Johan Ingemansson
Post by Pep » Wed Sep 08, 2004 8:38 am
Hi Johan,
No, that I know of. You need to sources to modify and recompilet them.
I've added this on our wish list to be considered for the next releases.
Marjan
Re: Possible for adjustment
Post by Marjan » Wed Sep 08, 2004 2:34 pm
9232649 wrote:Wouldn´t it be possible for Steema to make this adjustmentJohan Ingemansson
A bit tricky to do because you can't do it simply by using some flag(s). You have to recompile the packages with different declaration. The only solution for non-source code customers would be that we would prepare two sets of files (single and double compile) and prepare separate installers. However, at the moment we do not plan to do this. So, the only solution for non-source code customers is to upgrade to source code and build "single" packages manually.
Marjan Slatinek,
Johan Ingemansson
Post by Johan Ingemansson » Wed Sep 08, 2004 6:37 pm
Ok, I´ll do that!
Johan Ingemansson
Marcel Horsthuis
Re: Regarding TPointSeries, changing to Single from Double
Post by Marcel Horsthuis » Thu Dec 22, 2016 10:46 am
We want to user singles i.s.o doubles in TChartvalues.
The last post on this item is from 2004 where you have to have the source code to get this done.
Has something changed on this issue since then?
Marcel Horsthuis
Post by Sandra » Tue Dec 27, 2016 10:37 am
Hello Marcel,
I would like inform you that TChartValues, by default, are Doubles, therefore, if you want use these as single you still need modify the TeeChart source code in same way as we indicate above.
Thanks in advance
