Polar Grid
DieterMuc
Polar Grid
Post by DieterMuc » Mon Oct 17, 2011 3:59 pm
I work with C++Builder DS2007, Windows 7 and the latest TChart Version V2010.00.00407 Win32.
TChart-Series is: 3D -> Polar Grid -> Normal
During design-time I set the series1 to:Format -> Palette: Colors -> Rainbow and Invert, the steps to 22
During Runtime the series1 comes up with Format -> Palette -> Range what I do not need!
Only with the chart editor it is possible to set my parameters.
The following program-commands I found:
Series1 -> Palette -> PaletteStyle = psRainbow;
Series1 -> Palette -> PaletteSteps = 22;
But the result is none!
is there a way to set the desired parameter during runtime?
Thanks for an answer!
Dieter
Re: Polar Grid
Post by Yeray » Tue Oct 18, 2011 1:57 pm
Hello Dieter,
Try setting
  Series1->UsePalette = true;
  Series1->UseColorRange = false;
as described here
DieterMuc
Re: Polar Grid
Post by DieterMuc » Wed Oct 19, 2011 9:38 am
thank you, it works. But what I still miss is the statement to set Colors -> Invers!
Dieter
Re: Polar Grid
Post by Yeray » Wed Oct 19, 2011 11:47 am
Hi Dieter,
It's like this:
Series1->InvertPalette();
DieterMuc
Re: Polar Grid
Post by DieterMuc » Wed Oct 19, 2011 1:45 pm
here my code in C++ and it works:
Series1->Palette -> UsePalette = true;
Series1->Palette -> UseColorRange = false;
I Could not find a function: Series1 -> InvertPalette() or Series1 -> Palette -> InvertPalette() .
By the way: in Pascal-Examples I found the function.
Kind regards
Dieter
Re: Polar Grid
Post by Yeray » Wed Oct 19, 2011 2:22 pm
Hello Dieter,
I've just installed TeeChart v2010.00 in my RAD Studio 2007 and the InvertPalette function is recognized without problems as described above (Series1->InvertPalette(), being Series1 a TSurfaceSeries).
Please, check the library and include paths in your IDE (without any project opened) and try it again with a new simple application.
DieterMuc
Re: Polar Grid
Post by DieterMuc » Tue Oct 25, 2011 8:12 am
in TSurfaceSeries I found the function InvertPalette(), but I do not use this series. I must use TPolarGridSeries. And there is not function InvertPalette() available. I'm sorry. Try it by yourself!
Kind regards
Dieter
Re: Polar Grid
Post by Yeray » Tue Oct 25, 2011 3:05 pm
Hello Dieter,
In Delphi you can do as follows:
uses TeePolarGrid, TeeSurfa;
var polarGrid1: TPolarGridSeries;
  Chart1.View3D:=false;
  Chart1.Legend.Visible:=false;
  polarGrid1:=Chart1.AddSeries(TPolarGridSeries) as TPolarGridSeries;
  with polarGrid1 do
    FillSampleValues();
    Palette.UsePalette:=true;
    Palette.UseColorRange:=false;
var t   : Integer;
    tmp : TColor;
  with polarGrid1.Palette do
    for t:=0 to (Length(Palette) div 2)-1 do
      tmp:=Palette[t].Color;
      Palette[t].Color:=Palette[Length(Palette)-t-1].Color;
      Palette[Length(Palette)-t-1].Color:=tmp;
    PaletteStyle:=psCustom;
  Chart1[0].Repaint;
If you find problems translating it to C++Builder, don't hesitate to let us know.
DieterMuc
Re: Polar Grid
Post by DieterMuc » Thu Oct 27, 2011 1:32 pm
Now it works perfectly. If anybody is interestet in the C++ Code here it is:
void __fastcall TfmMainKennfeld::bbInversClick(TObject *Sender)
	TColor tmpColor;
	int iLength = polarGridSeries -> Palette -> PaletteSteps;
	for( int i = 0, j = iLength - 1; i < (iLength/2); ++i, --j )
		tmpColor = polarGridSeries -> Palette -> Palette[i].Color;
		polarGridSeries -> Palette -> Palette[i].Color = polarGridSeries -> Palette -> Palette[j].Color;
		polarGridSeries -> Palette -> Palette[j].Color = tmpColor;
	polarGridSeries -> Palette -> PaletteStyle = psCustom;
	Chart -> Repaint();
Thank you!
Kind regards
Dieter
Re: Polar Grid
Post by Yeray » Fri Oct 28, 2011 8:37 am
Hello Dieter,
I'm glad to hear that. And thanks for sharing! :D
