TTeePolygon
mpv
TTeePolygon
Post by mpv » Mon Sep 26, 2011 11:38 am
I want to dray a polygon and fill it with a calculated bitmap.
I followed an example from your site along these lines:
ASerie: TMapSeries;
APol: TTeePolygon;
ASerie:=TMapSeries.Create(Chart1);
ASerie.ParentChart:=Chart1;
ASerie.Pen.Color:=clWhite; // color of polygon line
APol:=ASerie.Shapes.Add;
APol.Color:=clRed; // color inside polygon
APol.Points.Clear;
for n := 1 to 10 do
APol.Points.AddXY(x,y);
In this case, the inside of the polygon will be solid red.
Is there a way to paint it with a custom bitmap ?
Regards, Matt
Re: TTeePolygon
Post by Narcís » Mon Sep 26, 2011 2:37 pm
Hi Matt,
You can assign a bitmap to the TMapSeries, for example:
uses TeeMapSeries;
  ASerie  : TMapSeries;
  APol    : TTeePolygon;
  MyBmp   : TBitmap;
  MyBmp:=TBitmap.Create;
  MyBmp.LoadFromFile('c:\temp\rocks.bmp');
  ASerie.Brush.Bitmap:=MyBmp;
  APol.Points.Clear;
  with APol.Points do
    AddXY(1,1);
    AddXY(1,10);
    AddXY(10,10);
    AddXY(10,1);
mpv
Re: TTeePolygon
Post by mpv » Mon Oct 03, 2011 9:23 pm
Thanks Narcis, that works. I obviously used the wrong brush here.
I would like to add some marks for the polygon, but I have only managed to get a single mark in the middle for the TMapSeries.
Is it at all possible to add marks to points of a polygon?
As a workaround, I could add a number of line series, which would have the same points, and use these to generate the marks from.
Regards, Matt
Re: TTeePolygon
Post by Yeray » Wed Oct 05, 2011 8:16 am
Hello Matt,
As you've seen, the TMapSeries shows a mark for each shape, in the centre of the shape.
If you want a mark at each point/edge, the easiest solution would be using an extra series (like a TPointSeries) with a point for each edge. Here it is a simple example:
uses TeeMapSeries, Series;
  AMSerie : TPointSeries;
  APol    : TTeePolygon;
  MyBmp   : TBitmap;
  i       : Integer;
  Chart1.Legend.Visible:=false;
  Chart1.View3D:=false;
  AMSerie:=TPointSeries.Create(Chart1);
  AMSerie.ParentChart:=Chart1;
  AMSerie.Marks.Visible:=true;
  AMSerie.Marks.Style:=smsXY;
  AMSerie.Pointer.Visible:=false;
  APol.Points.Clear;
  with APol.Points do
    AddXY(1,1);
    AddXY(1,10);
    AddXY(10,10);
    AddXY(10,1);
    for i:=0 to Count-1 do
      AMSerie.AddXY(XValue[i], YValue[i]);
