Conlicts with base class 'TWinControl'
Posted: Tue Sep 20, 2011 11:54 am
by 16457425
I have just upgraded my TeeChart from 2010.01 to 2011.03 into C++Builder 2007 and I get a C++ Error that wasn't occurring before:
Teeprocs.hpp(717): E2113 Virtual function '__fastcall TCustomTeePanelExtended::GetDeviceContext(HWND__ *&)' conflicts with base class 'TWinControl'
Has anyone else seen this error and have a workaround/fix? I couldn't find anything on this in this forum.
Thansk in antincipation.
Andrew Bond
Re: Conlicts with base class 'TWinControl'
Posted: Tue Sep 20, 2011 1:43 pm
by narcis
Hi Andrew,
Does this occur in a specific project or with all TeeChart related projects? Have you checked that your C++ Builder Include and Library search paths point to new TeeChart version "Include" and "Lib" folders?
Posted: Tue Sep 20, 2011 2:49 pm
by 16457425
Narcis
Thanks for the quick response. My TEEINCPATH and TEELIBPATH environment variables are set correctly (to ..\TeeChart 2011 for Delphi 2007\..).
It appears the problem occurs because I am also using Developer Express controls (version 2011.1.6) and - in particular - DevEx's Printing System library, which supports TeeChart.
Currently, my source fails to compile because DevEx's <dxPSTCLnk.hpp> file is included BEFORE Steema' <Chart.hpp>.
If I force the inclusion of <Chart.hpp> ahead of <dxPSTCLnk.hpp> then it compiles ok.
Perhaps this is something to do with overriding STRICT (which i have set to true)? That would change the function's signature, owing to HWND being different with/without STRICT.
Were you aware of this incompatibility with DevEx? (I will ask the same question on their website.)
Posted: Tue Sep 20, 2011 3:22 pm
by narcis
Hi Andrew,
Thanks for your feedback.
No, I wasn't aware of that but it's Developer Express who does the TeeChart integration with their components. Actually a similar issue was discussed in
his thread at DevExpress' forums, it might be helpful for you as well.
