TeeChart 2011 Installation for Delphi XE
Byron Upchurch
Post by Byron Upchurch » Wed Aug 17, 2011 6:43 pm
After running the installation for "TeeChart Pro 2011 with Full Source Code", the Install.txt does not identify an installation procedure for Delphi XE. What is the proper, step-by-step installation procedure for installing it on Delphi XE?
Re: TeeChart 2011 Installation for Delphi XE
Post by Yeray » Thu Aug 18, 2011 11:36 am
Hello Byron,
When installing source code versions we first recommend to install the binary installers to obtain help files, documentation, tutorials, demos, etc. Once this is done we recommend to run the TeeRecompile tool in the source code installation to compile and install packages to selected IDEs.
Byron Upchurch
Post by Byron Upchurch » Thu Aug 18, 2011 3:06 pm
Thanks for the response. Where would I find the binary installer? The Install.txt file mentions "gacutil", but does not refer to it as a binary installer; is this what I need to run?
Post by Yeray » Fri Aug 19, 2011 2:55 pm
Hello Byron,
Byron Upchurch wrote: Where would I find the binary installer?
Login in the client are with your license information
http://www.steema.com/clientaccess
