Dash line appearing as straight line
In the editor I set the style of a line series to dash lines but in the report where the chart is printed it always appears as a straight line. Any idea why this is happening?
Vincenzo
P.S. Cannot attache screen-shots as an error message appears saying the board quota has been reached.
Vincenzo
Re: Dash line appearing as straight line
Which version of Delphi and TeeChart are you using?
Delphi 2009 and TeeChart Pro V.8.04.11395 Win32
Hm, I don't have version 8 but I know that 8.04 is not the latest release. My suggestion is to install 8.08 and see if the problem persists.
Yes, please try it with the latest release available at the client area and, if the problem persists, please tell us what reporting component are you using and try to arrange a simple example project we can run as-is to reproduce the problem here.
Thanks for your replies. It's not crucial for me to have a dashed line and installing the latest version just to try it out is too much hassle (have to re-install my current version again later).
Vincenzo
Vincenzo
Hello Vincenzo,
I understand it's not a critical problem but we'll be pleased to take a look at it if we can reproduce it here. But to do so, we'd need to know what reporting component are you using and it would be also really helpful if we could have a simple example project we can run as-is to reproduce the problem here.
Hi Alonso,
Meanwhile I found out that it has nothing to do with the report component. The line is shown as straight line (instead of dashed) if the vertical axis assigned is the right one (if it's the left it's drawn correctly as dashed). I have created a small example program if you need it, where can I upload it?
Vincenzo
Vincenzo
Hi Vincenzo,
You can attach files to this forums board in your replies. You can compress your project in a zip packages and attach it to your reply.
Sample program attached.
- test2.zip
- (14.3 KiB) Downloaded 1192 times
Hello Vincenzo,
The problem here is that the distance between each two points isn't enough for the Dash pen style to be noticed. Note that the line series is drawn in segments.
Here you have an example:
An option would be to use psDot style instead of psDash.
Find here a more complete explanation of it.
uses Chart, Series;
var Chart1: TChart;
Series1: TLineSeries;
var i: Integer;
Chart1:=TChart.Create(Self);
Chart1.Parent:=Self;
Chart1.Color:=clWhite;
Chart1.View3D:=false;
Chart1.Legend.Visible:=false;
Chart1.Axes.Bottom.Grid.Visible:=false;
Chart1.Axes.Left.Grid.Visible:=false;
Series1:=Chart1.AddSeries(TLineSeries) as TLineSeries;
Series1.Pen.Style:=psDash;
for i := 0 to 10 do
Series1.Add(12+i);
//Series1.Pointer.Visible:=true;
Chart1.Axes.Bottom.SetMinMax(0, 20);
Chart1.Axes.Left.SetMinMax(10, 22);
Chart1.Draw;
procedure TForm1.FormPaint(Sender: TObject);
var YDispl, XDispl, i: Integer;
YDispl:=300;
XDispl:=50;
with Self.Canvas do
Pen.Style:=psDash;
MoveTo(Series1.CalcXPos(0),Series1.CalcYPos(0)+YDispl);
LineTo(Series1.CalcXPos(Series1.Count-1),Series1.CalcYPos(Series1.Count-1)+YDispl);
for i:=0 to Chart1[0].Count-2 do
MoveTo(Series1.CalcXPos(i)+XDispl, Series1.CalcYPos(i)+YDispl);
LineTo(Series1.CalcXPos(i+1)+XDispl, Series1.CalcYPos(i+1)+YDispl);
Thanks for investigating this, I do understand the explanation but nevertheless it would be good if Teechart would automatically convert to dot (or shorter lines) if dashes cannot be drawn.
Vincenzo
Vincenzo
Hi Vincenzo,
TeeChart could include it (or better, the option to check it or not, for not to break backwards compatibility) but it would mean many new conditions (one for each segment to be drawn) so it could affect the performance even for those who use psSolid but have thousands of points.
So I'd suggest you to check it in your code. The following works for me here:
uses Chart, Series, TeCanvas;
var Chart1: TChart;
var i: Integer;
d: double;
for i := 0 to 10 do
Series1.Add(12+i);
if Series1.Pen.Style=psDash then
for i:=0 to Series1.Count-2 do
d:=TeeDistance(Series1.CalcXPos(i+1)-Series1.CalcXPos(i),Series1.CalcYPos(i+1)-Series1.CalcYPos(i));
if (d < 25) then
Series1.Pen.Style:=psDot;
exit;
Thanks for the code sample and I understand that for performance reasons it wouldn't be a good idea to include the automatic switch.
Vincenzo
Vincenzo
- Newbie
in my TeeChart project (using TeeChart 2010 and Delphi 2010) I found the same problem as discussed in these posts/replys. However, I observed that this problem seems to be somewhat more general: even a dot-style series "melts" into a solid line if the number of points per page exceeds a certain level (Zooming such a line would restore the dot style).
The chart applications that I am developing with TeeChart, usually contain more than 5 line series within the chart. Of course, to distinguish them from each other it is necessary to use not only different colors but also different styles (solid, dash, dot...).
So, in my opinion the pen style appearance of a series should not be affected by the number of series points, although I can imagine that handling this won't be an easy job for the component developers
Do you see any chance, to solve this problem in one of the next releases?
Andreas
Andreas
