TeeMaps Example - Unit TeeSurfa was compiled with a differe
SweetLekDude
Post by SweetLekDude » Sun Mar 13, 2011 3:16 pm
I am running the TeeMap example for the first time (Delphi XE ...TeeChart Pro 2010.02)
and I get the following
[DCC Fatal Error] UnitTestSHP.pas(22): F2051 Unit TeeSurfa was compiled with a different version of Chart.TCustomChart
How do I get past this issue?
Do I change the library path?
Re: TeeMaps Example - Unit TeeSurfa was compiled with a differe
Post by Yeray » Tue Mar 15, 2011 3:13 pm
Hi SweetLekDude,
Check that the TeeChart library directory is in the top of you IDE library path list.
As you presume, this error usually means that there is a confusion in your IDE, finding previous installations files before than the new ones.
