TIsoSurfaceSeries and XZ plot
Posted: Thu Feb 17, 2011 6:33 pm
by 10553474
Hi!
I am trying to draw an array of values with the TIsoSurfaceSeries, and I want to display my data in XZ-plane. The problem is that when I set View3D:=false, TeeChart is using XY-plane to display the data. How can I set up 2D views of TIsoSurfaceSeries' objects (TeeChartPro 8.05)?
Re: TIsoSurfaceSeries and XZ plot
Posted: Fri Feb 18, 2011 12:04 pm
Hi toxi,
Have you tried using a ColorGrid instead of a Surface in 2D or viewed from the top?
Suface Series viewed from the top:
uses TeeSurfa;
var x, z: integer;
Chart1.Chart3DPercent:=100;
Chart1.Aspect.Orthogonal:=false;
Chart1.Aspect.Zoom:=70;
Chart1.Aspect.Rotation:=0;
Chart1.Aspect.Elevation:=270;
Chart1.Legend.Visible:=false;
with Chart1.AddSeries(TSurfaceSeries) as TSurfaceSeries do
for x:=0 to 9 do
for z:=0 to 9 do
AddXYZ(x, random*10, z);
ColorGrid Series:
uses TeeSurfa;
var x, z: integer;
Chart1.View3D:=false;
with Chart1.AddSeries(TColorGridSeries) as TColorGridSeries do
for x:=0 to 9 do
for z:=0 to 9 do
If that's not what you are trying to do, please try to arrange a simple example project we can run as-is to reproduce the problem here.
Posted: Fri Feb 18, 2011 9:02 pm
by 10553474
Thanks! Your answer was helpful. But I have some problems.
1) There is no filled area on the Fig.1. Values Y=YValues.MaxValue (13e-4) are located under no filled area.
2) When I zoom, surface is out of axis (fig. 2).
Fig .1
Fig. 2
Posted: Tue Feb 22, 2011 1:55 pm
Hi toxi,
toxi wrote:1) There is no filled area on the Fig.1. Values Y=YValues.MaxValue (13e-4) are located under no filled area.
Could you please try to arrange a simple example project we can run as-is to reproduce the problem here?
toxi wrote:2) When I zoom, surface is out of axis (fig. 2).
You could try doing something similar to the demo at "All features\Welcome !\Axes\Opaque zones" in the feature demo program included in the installation.
If you still have problems with it, don't hesitate to let us know.
Posted: Wed Feb 23, 2011 12:40 am
by 10553474
Hi Yeray
I uploaded TestIsoSurf.zip. Project compiled with Delphi 6 and TeeChartPro v.8.07.
There are problems in this project:
1) The array of values from Data.xml (program load it when started) is painted not correctly in the TeeChart. But a ChartEditor.Data's table shows perfectly this data when button "3D" is not down. If the ChartEditor.Data's button "3D" is down, table shows the array of data also not correctly. Source_Field.xml contains the field of data, which I am trying to draw using TeeChart
2) There is no filled area with a values=YValues.MaxValue
3) The problem with zoom is disappear in TeeChart 8.07 (Early I used 8.05) , about which I wrote in the previous post. But zoomed area is shifted relatively the left-top point of zoom's rectangle in this version.
I'm sorry, my English is bad.
Please help!
Posted: Fri Feb 25, 2011 12:01 pm
Hi toxi,
We think this could be probably better to be drawn with a Contour or a ColorGrid series. Here is how it looks changing the series to a Contour series:
procedure TFIsoSurf.FormCreate(Sender: TObject);
var tmpSeries: TChartSeries;
{ Chart1.Chart3DPercent:=100;
Chart1.Aspect.Perspective:=0;
Chart1.View3D:=False;
Chart1.Legend.Visible:=true;
XMLSource.FileName:=ExtractFileDir(paramstr(0))+'\Data.xml';
XMLSource.Load;
TIsoSurfaceSeries(Chart1.Series[0]).PaletteSteps:=4;
TIsoSurfaceSeries(Chart1.Series[0]).ValueFormat:='00e-0';
tmpSeries:=Chart1[0];
ChangeSeriesType(tmpSeries, TContourSeries);
- Contour.jpg (122.49 KiB) Viewed 6585 times
Posted: Sun Feb 27, 2011 7:42 pm
by 10553474
There was a mistake on the screenshot from your previuos post: the central area of figure must not be grey colored. Maybe it is a bug with a Palette using. I found what the subfunction CalcFirstLevel of method TIsoSurfaceSeries.DrawCell(x, z: Integer) returns the wrong result - second level in palette. I changed the CalcFistLevel how it looks below. You can see the result on screenshot. It seems that the Controurseries and IsoSurfaceSeries fill correctly.
TeeSufra.pas
procedure TIsoSurfaceSeries.DrawCell(x, z: Integer);
function CalcFirstLevel:Integer;
var i: Array[0..3] of Integer;
t: Integer;
tmpM,
tmpV : TChartValue;
// Search first palette level
i[0]:=ValueIndex0;
i[1]:=ValueIndex1;
i[2]:=ValueIndex2;
i[3]:=ValueIndex3;
tmpMin:=i[0];
tmpV:=v[tmpMin];
tmpM:=tmpV;
tmpMax:=tmpMin;
for t:=1 to 3 do
if v[i[t]]<tmpV then
tmpV:=v[i[t]];
tmpMin:=i[t];
end
if v[i[t]]>tmpM then
tmpM:=v[i[t]];
tmpMax:=i[t];
result:=-1;
for t:=0 to PaletteLength-1 do
With Palette[t] do
//if UpToValue>tmpV then
// fix
if UpToValue>=tmpV then
result:=t;
break;
Filled ContourSeries
Posted: Mon Feb 28, 2011 2:48 pm
Hi toxi,
I've added your suggestion to the wish list to be studied for future releases (TV52015423).
Anyways, I'm glad to see you've found a way to draw it as you want.
Posted: Fri Mar 25, 2011 11:05 am
by narcis
Hi toxi,
Thanks for your feedback. Just wanted to let you know that I have included your enhancement suggestion for next TeeChart VCL release.
