refresh issue of tdbchart with dual monitor
MDATeam
Post by MDATeam » Thu Jan 27, 2011 7:35 am
Hi ,
Ours is legacy MDI application ( built initally with borland c++ 6 and mighrated to bcb2009 -> and then to bcb2010) having teechart on the vcl form. Now we have faced problem with refresh of the teechart component while working with double monitor.
I explain the steps.
1. Enable the double monitor and then make the application active. The MDI child forms have tdbchat drawn with some series ( > 20 ) and one form is active.
2. drag the application to 2nd monitor and maximize.
3. again minimize and drag to 1st monitor and maximize.
if I try these steps I see tdbchart is not completely refreshed on the screen and we see grey color on half of the tdbchart.
Please let me know if any one faced these types of problems. Hints are welcome.
Re: refresh issue of tdbchart with dual monitor
Post by Narcís » Fri Jan 28, 2011 11:47 am
Hi MDATeam,
I'm not able to reproduce the issue here using our latest TeeChart v2010 VCL sources with attached project. Which TeeChart version are you using? Can you please check if it works fine at your end? If it doesn't could you please let us know the exact steps we should follow or prepare a vide with which we can see what should we exactly do to reproduce the problem here?
For recording video you can use CamStudio, a free scree recording application.
prMDIExample.zip
(4.32 KiB) Downloaded 256 times
