Creating Pie Series In Code
Nigel Tavendale
Post by Nigel Tavendale » Tue Dec 14, 2010 5:04 am
Trying to create a Pie Series connected to a TClientDataSet in code.
procedure TMyForm.CreateChart;
  pieSeries: TPieSeries;
  i: Integer;
  MyChart.View3D := FALSE;  //MyChart is a TeeChart On The From
  Screen.Cursor := crHourglass;
  try
    for i:= (MyChart.SeriesCount -1) downto 0 do
      MyChart.Series[i].Free;
    MyChart.SeriesList.Clear;
    pieSeries := TPieSeries.Create(MyChart);
    pieSeries.ParentChart := MyChart;
    pieSeries.DataSource := cdsChartData;  //cdsChartData is The TClientDataSet with the data I want to display
    pieSeries.PieValues.ValueSource := 'YearTotal';  //Field
    pieSeries.XLabelsSource := 'SliceLabel';  //Labels for the different values
    MyChart.SeriesList.Add(pieSeries);
    MyChart.Title.Text.Clear;
    MyChart.Title.Text.Add(''My Pie Series');
    GetData(); //Loads the Dataset by opening it
    pieSeries.CheckDataSource;
  finally
    Screen.Cursor := crDefault;
There are two problems I am running into.
1) The Pie chart is not flat. Instead it is on an angle like it is trying to be a 3D chart. How do I stop it from doing this?
2) When I close the form (after the chart is loaded) I get an Exception (Invalid Pointer Operation). I think that has something to do with the Series and it's parent.
I combed the examples but they all seem to be examples with the series created at design time. I need to do it at run time.
Nigel Tavendale
Re: Creating Pie Series In Code
Post by Nigel Tavendale » Wed Dec 15, 2010 4:55 am
Removing the following
gets rid of the Exception. Only now the pie chart is invisible. The lables are sill there, which makes me think the pie is too, just with a radius so small I can't see it on the screen.
Does anyone have any idea what I am doing wrong?
Post by Yeray » Wed Dec 15, 2010 2:13 pm
Hi Nigel,
Simplifying your example (because I don't have your datasource) I have the following:
uses series;
var pieSeries: TPieSeries;
  Chart1.View3D := FALSE;
  pieSeries := TPieSeries.Create(Chart1);
  pieSeries.ParentChart := Chart1;
  pieSeries.FillSampleValues();
The code above in a new simple project with only a chart on the form seems to work fine here. So maybe you are doing something wrong at designtime or at GetData(). Or maybe there is something wrong with the data itself but I doubt it.
You can try adding resetting the settings of your chart to the defaults at the beginning of your CreateChart procedure. This would eliminate the suspect of some wrong setting at design time.
