Error compiling TeeUI97Clx.dpk with TeeRecompile
WJEC
Post by WJEC » Sun Dec 12, 2010 3:35 am
I just updated to TeeChart2010 and have some Delphi 7 code that requires CLX. When I compile the TeeChart 2010 CLX source for Delphi 7 usiing TeeRecompile I get the following error.
TeeUI97Clx
Cannot recompile Delphi package: TeeUI97Clx.dpk
Borland Delphi Version 15.0
Copyright (c) 1983,2002 Borland Software Corporation
TeeGally.pas(632) Error: Incompatible types: 'String' and 'TTab'
TeeGally.pas(642) Error: Incompatible types: 'String' and 'TTab'
TeeUI97clx.dpk(97) Fatal: Could not compile used unit 'TeeGally.pas'
EXCEPTION:
Compilation aborted.
When I inspect the error locations and associated variables the error message appears valid.
Any help would be appreciated
Re: Error compiling TeeUI97Clx.dpk with TeeRecompile
Post by Yeray » Tue Dec 14, 2010 3:57 pm
Hi WJEC,
I could reproduce it so I've added it to the defect list to be fixed in future releases (TV52015321).
Post by Narcís » Mon Jan 17, 2011 12:31 pm
Hi WJEC,
We have revised TV52015321 now and a considerable amount of code should be rewritten for the version to compile in CLX environments and there are no plans to do so at the present moment. Could you please try if using 2010.00.00407 works fine for you?
