I need the legend to be to the right of the chart, but I want it to be aligned to the bottom rather than the top of the chart.
How can I do that?
Ed Dressel
Legend Position
- Advanced
Re: Legend Position
Hi Ed,
You could place your legend manually like following:
uses series;
var i: Integer;
for i:=0 to 4 do
with Chart1.AddSeries(TBarSeries) do FillSampleValues;
Chart1.Draw;
Chart1.MarginUnits:=muPixels;
Chart1.MarginRight:=100;
Chart1.Legend.CustomPosition:=true;
Chart1.Legend.Left:=Chart1.Width-Chart1.Legend.Width-10;
Chart1.Legend.Top:=Chart1.Axes.Bottom.PosAxis-Chart1.Legend.Height-10;
- Advanced
Re: Legend Position
This works until I resize the chart--the legend stays in the same location.
I tried some before/after draw events, and they did not work.
Any suggestions?
Ed Dressel
Any suggestions?
Ed Dressel
Re: Legend Position
Hello Ed,
I have done next example using OnAfterDraw event and works fine for me.
Could you please, tell us if previous code works as you want? If code doesn't work fine for you please, explain us which is the exactly problem.
var i: Integer;
for i:=0 to 4 do
Chart1.Align:= alClient;
Chart1.Draw;
- Advanced
Re: Legend Position
The attached demo (using 8.06) draws the legend in the wrong location the first time. After a redraw, it works fine.
Ed D
Ed D
- Legend Location 2.zip
- (2.99 KiB) Downloaded 651 times
Re: Legend Position
Hello TestAlways,
If you want that legend location would be correct the first time, you need added Chart1.Draw twice in from create as do in next lines of code:
I also inform you, there is recent version of TeeChartVCL(8.07) you can download it here.
constructor TForm2.Create(aOnwer: TComponent);
inherited;
Series1.FillSampleValues(20);
Series2.FillSampleValues(20);
Series2.Title := 'this is a long description';
Chart1.Draw;
Chart1.Draw;
// Chart1.MarginRight:=100;
