Cross hair not drawn when labels are on Chart
ChartIt
Post by ChartIt » Wed Nov 24, 2010 7:56 pm
It seems like I have an issue with TChart 2010.
I use the following code to draw a cross hair on a Chart that follows the mouse when moved on the Chart.
The cross hair is following the mouse perfectly if I don't place the two labels "lblHorizontalAxis" and "lblVerticalAxis" directly on the Chart (but place them on the form behind the Chart). The labels are showing some values that are extracted from the Chart while the mouse is moving.
The problem occurs if I place the labels on the Chart itself (where they actually belong).
The labels are getting updated, and following the mouse as they should, but the cross hair is only drawn ones when pressing the mouse, but not following the mouse (which means it doesn't get deleted and redrawn in the OnMouseMove event).
I'm pretty sure I didn't have this problem with TChart 7.
Do you know what has happened, or do you need more explanation/code?
Thanks in advance!
procedure TfrDataLogger.DrawCross(AX, AY: Integer);
with Chart1, Canvas do
Pen.Color := clWhite;
Pen.Style := psSolid;
Pen.Mode := pmXor;
Pen.Width := 1;
//Vertical line:
MoveTo(ax, ChartRect.Top);
LineTo(ax, ChartRect.Bottom);
//Horizontal line:
MoveTo(ChartRect.Left, ay);
LineTo(ChartRect.Right, ay);
procedure TfrDataLogger.Chart1MouseDown(Sender: TObject; Button: TMouseButton;
if ((FAnalyzeMode = Rule) or (FAnalyzeMode = Tracker) or (FAnalyzeMode = Vernier)) and (Button = MBLeft) then
Chart1[0].GetCursorValues(FStartVernierX, FStartVernierY);
lblHorizontalAxis.Visible := True;
lblVerticalAxis.Visible := True;
if PtInRect(Chart1.ChartRect, Point(X-Chart1.Width3D,Y+Chart1.Height3D)) then //Check if mouse is inside Chart rectangle.
FDrawCrossActive := True;
DrawCross(x, y); //Draw crosshair at current position.
//Store current position:
FOldX := x;
FOldY := y;
//In case of Vernier the first drawn crossHair must remain:
if (FAnalyzeMode = Vernier) then
FOldX := -1;
procedure TfrDataLogger.Chart1MouseMove(Sender: TObject; Shift: TShiftState; X, Y: Integer);
tmpX, tmpY: Double;
Chart1[0].GetCursorValues(tmpX, tmpY);
if FAnalyzeMode = Rule then
lblHorizontalAxis.Caption := FloatToStr(RoundTo(tmpX,-2));
lblHorizontalAxis.Top := Chart1.Axes.Bottom.PosLabels;
lblHorizontalAxis.Left := Chart1.GetCursorPos.X - round(lblHorizontalAxis.Width/2);
lblVerticalAxis.Caption := FloatToStr(RoundTo(tmpY,-2));
lblVerticalAxis.Top := Chart1.GetCursorPos.Y - round(lblVerticalAxis.Height/2);
lblVerticalAxis.Left := Chart1[0].GetVertAxis.PosLabels - lblVerticalAxis.Width;
if (FAnalyzeMode = Tracker) and (Chart1[0].Count <> 0) then
lblVerticalAxis.Caption := FloatToStr(Chart1[0].YValue[Round(tmpX)]);
//lblVerticalAxis.Caption := FloatToStr(RoundTo(tmpY,-2));
if FAnalyzeMode = Vernier then
lblHorizontalAxis.Caption := FloatToStr(RoundTo(tmpX - FStartVernierX, -2));
lblVerticalAxis.Caption := FloatToStr(RoundTo(tmpY - FStartVernierY, -2));
//Delete old crossHair:
if ((FAnalyzeMode = Rule) or (FAnalyzeMode = Tracker) or (FAnalyzeMode = Vernier)) and (FDrawCrossActive) then
if (FOldX <> -1) then
DrawCross(FOldX, FOldY); //Delete old crossHair.
FOldX := -1;
//Check if mouse is inside Chart rectangle:
FOldX := x;
FOldY := y;
Re: Cross hair not drawn when labels are on Chart
Post by Yeray » Thu Nov 25, 2010 9:37 am
Hi ChartIt,
There are some variables in your code snipped undefined so we can't run it as-is. Please, try to arrange a simple example project we can run as-is to reproduce the problem here.
However, if I understood well, you are trying to achieve something similar to the Cursor Tool. Take a look at the examples under "All features\Welcome !\Tools\Cursor\".
Here you have a simple example:
uses Series, TeeTools;
  Chart1.View3D:=false;
  Chart1.Legend.Visible:=false;
  with Chart1.AddSeries(TPointSeries) do FillSampleValues;
  with Chart1.Tools.Add(TCursorTool) as TCursorTool do
    FollowMouse:=true;
ChartIt
Post by ChartIt » Thu Nov 25, 2010 1:46 pm
I didn't know that function, thanks for that!
Anyway, the problem seems to be here too.
Put a label to a new Chart, and add this code:
Y: Integer);
tmpX, tmpY: Double;
Label1.Caption := FloatToStr(Round(tmpX));
i: Integer;
Chart1.View3D := False;
Chart1.Legend.Visible := False;
Chart1.AddSeries(TFastLineSeries);
for i := 0 to 200 do
Chart1.Series[0].AddXY(i, i, '', clRed);
FollowMouse := True;
Without updating the label in OnMouseMove everything works fine.
When updating the label (like in the code above) the cursor tool doesn't get drawn.
What do you say?
Post by Yeray » Thu Nov 25, 2010 3:38 pm
Hi ChartIt,
The attached project seems to run fine for me here. Could you please tell us what we have to do to reproduce the problem with it?
MouseMoveUpdate.zip
(1.74 KiB) Downloaded 1538 times
Are you using the latest TeeChart version available (v2010.01)?
ChartIt
Post by ChartIt » Thu Nov 25, 2010 4:39 pm
I use the latest version. Downloaded yesterday :)
If you delete the line:
Chart1.Title.Text.Text:=FloatToStr(Round(tmpX));
you should also see the problem.
ChartIt
Post by ChartIt » Thu Nov 25, 2010 5:02 pm
By adding the line
Chart1.Repaint;
or
Chart1.Refresh;
at the end of the MouseMove event the cross hair gets redrawn, but then it draws on top of the label.
This is not the case when using the line
Chart1.Title.Text.Text := FloatToStr(Round(tmpX));
Post by Yeray » Fri Nov 26, 2010 9:52 am
Hi ChartIt,
Excuse me, I'm not sure how I was looking at this.
Yes, it seems that, for some reason, when updating a label (with the chart as parent) in the OnMouseMove event (also happens with the tool's OnChange event), the Cursor Tool stops following the mouse. I've added it to the wish list to be investigated for further releases (TV52015292).
As you say, the Chart1.Repaint and the Chart1.Refresh methods work around this. Also you could consider using Annotation tools, Rectangle tools or custom drawing the text on top of the chart instead of using labels.
ChartIt
Post by ChartIt » Fri Nov 26, 2010 9:58 am
OK, but please note that Repaint and Refresh don't solve the problem completely, see my previous post.
Do you happen to be able to help me out with my newest post in this forum regarding retrieving YValues? :)
Post by Yeray » Fri Nov 26, 2010 10:11 am
Hi ChartIt,
And what about this?
Chart1.Tools[0].Repaint;
ChartIt wrote:Do you happen to be able to help me out with my newest post in this forum regarding retrieving YValues? :)
Of course, as soon as possible.
ChartIt
Post by ChartIt » Fri Nov 26, 2010 10:18 am
That seems to work, thanks!
