Add Axis at Runtime
Roy
Add Axis at Runtime
Post by Roy » Mon Nov 15, 2010 2:28 pm
Would like to add a Right Axis to a Chart at runtime and then add a new data series that uses this Right Axis and existing Bottom Axis. How do you associate a series to the specific Axis desired?
Re: Add Axis at Runtime
Post by Yeray » Tue Nov 16, 2010 1:42 pm
Hi Roy,
You can assign a series to the right axis as follows:
Series1.VertAxis:=aRightAxis;
Or to use both Left and Right Axis:
Series1.VertAxis:=aBothVertAxis;
Or you can create a Custom axis and assign it to one or several series. You can see examples of it at "Tutorial 4 - Axis Control".
By default the series use the Bottom axis, so you shouldn't need to change it.
Roy
Post by Roy » Tue Nov 16, 2010 2:44 pm
Thanks. That should do what I need.
