TeeChart 2010 and Title alignment
johnnix
Post by johnnix » Thu Sep 30, 2010 5:35 am
Long time ago I posted a question regarding on how I can align the chart Title caption relative to left and right axis area. Apparently I have the same issue with 2010 version.... Is it possible to do so as it looks really ugly :(
Re: TeeChart 2010 and Title alignment
Post by Yeray » Thu Sep 30, 2010 1:38 pm
Hi johnnix,
If I understood correctly, you could set your title position relative to an axis position doing something as follows:
uses series;
  Chart1.Title.Left:=Chart1.Axes.Left.PosAxis;
  Chart1.Title.Top:=10;
  Chart1.Align:=alClient;
  Chart1.View3D:=false;
  Chart1.MarginTop:=8;
  Chart1.Title.CustomPosition:=true;
  Chart1.Title.Text.Text:='My custom title aligned';
  Chart1.Title.Font.Size:=10;
  Chart1.Title.Font.Color:=clRed;
  with Chart1.AddSeries(TPointSeries) do FillSampleValues();
  Chart1.Draw;
johnnix
Post by johnnix » Fri Oct 01, 2010 5:16 am
Thank you for your reply. The code you sent me does not work exactly as I wanted. Below is a sample where you may see that there is a difference (the blue title is the right one):
var l, r, w, x,y: integer;
  l := Chart1.Axes.Bottom.IStartPos;
  r := Chart1.Axes.Bottom.IEndPos;
  chart1.Canvas.Font.Assign(chart1.Title.Font);
  chart1.Canvas.Font.Color := clBlue;
  w := Chart1.Canvas.TextWidth(chart1.Title.Caption);
  chart1.Title.Left := round(l + (r-l)*0.50 - w*0.50);
  chart1.Canvas.TextOut(round(l + (r-l)*0.50 - w*0.50),8,chart1.Title.Caption);
  chart1.Series[0].ShowInLegend := false;
  Chart1.Draw;
Kindest regards
Post by Narcís » Fri Oct 01, 2010 2:59 pm
Hi johnnix,
This is because you have to take into account the horizontal separation between the title text and its bounding shape, you'll see what I mean in this code snippet:
uses Series;
var l, r, w, x, y, pos: integer;
  w := Chart1.Canvas.TextWidth(Chart1.Title.Caption);
  pos:=round(l + (r-l)*0.50 - w*0.50);
  Chart1.Title.Left:=pos;
  Chart1.Canvas.Font.Assign(Chart1.Title.Font);
  Chart1.Canvas.Font.Color:=clBlue;
  Chart1.Canvas.TextOut(pos,8,Chart1.Title.Caption);
  Chart1.Title.Transparent:=False;
  Chart1.AddSeries(TPointSeries.Create(Self)).FillSampleValues();
  Chart1[0].ShowInLegend:=false;
  Chart1.Draw;
In the code above you can see how custom drawn text aligns perfectly with title's frame. I'm afraid there's no property to control text's margin.
