Align left and right axes
neo
Post by neo » Thu Sep 16, 2010 9:12 pm
I'm trying to align the left and right axes. I want the grid lines to nicely overlap even though the scales are different. The chart is created at runtime and is only ever drawn onto a bitmap.
neo
Re: Align left and right axes
Post by Narcís » Fri Sep 17, 2010 7:23 am
Hi neo,
In that case you could do as discussed in this thread. This is a TeeChart for .NET thread but same principles apply to TeeChart VCL.
neo
Post by neo » Fri Sep 17, 2010 6:11 pm
Thanks Narcis.
I've read through the thread and tried to get it working but I haven't had any luck. I'm not sure this thread gives me exactly what I'm looking for. My left and right axis differ in scale and units. The left axis also contains a number of lines (i.e. line series) whereas the right axis only contains 1 line.
For example consider the following:
Left axis is in 'meters' and has 10 lines. Each line has a different y value for a given x value but all y values for all lines fall in between 0 and 20 meters.
Right axis is in 'seconds' and there is only one. This line have y values between 200 and 10000 seconds.
How can I configure the chart to have the grid lines synchronize with each other? I can't call SetMinMax with the same values for each axis because they are completely different units.
I was also wondering if you could help me convert the following (from the thread) into pascal:
            tChart1.Axes.Right.StartEndPositionUnits = Steema.TeeChart.PositionUnits.Pixels;
Post by Yeray » Mon Sep 20, 2010 8:11 am
Hi neo,
Here it is a simple example trying to simulate the situation you described. I've achieved the synchronized axes labels with custom labels in the right axis:
uses series;
var i, n: Integer;
  Chart1.View3D:=false;
  for n:=0 to 1 do
    with Chart1.AddSeries(TFastLineSeries) do
      for i:=0 to 14 do
        Add(Random*20);
    VertAxis:=aRightAxis;
    for i:=0 to 14 do
      Add(200+Random*9800);
  Chart1.Draw;
  ReCalcRightLabels;
procedure TForm1.ReCalcRightLabels;
var i: Integer;
    tmp: double;
  Chart1.Axes.Right.Items.Clear;
  with Chart1.Axes.Left do
    for i:=0 to Items.Count-1 do
      tmp:=Chart1.Axes.Right.CalcPosPoint(CalcPosValue(Items[i].Value));
      Chart1.Axes.Right.Items.Add(tmp, FormatFloat('#.##', tmp));
neo
Post by neo » Mon Sep 20, 2010 8:22 pm
Thanks for your suggestion. I'm sure this would work fine if my TChart's parent was a TForm. I guess the biggest problem is that my TChart does *not* have a parent that is utimately a TForm. This thread seems to discuss the problem I am having:
http://www.teechart.net/support/viewtop ... ndow#p3185
Unfortunately the aforementioned thread suggests modifying the TChart source that I don't have. If I try to manually draw a TChart (i.e myChart.Draw) I receive an EInvalidOperation with message 'Control " has no parent window'.
I'd prefer to leave my TChart "Form-less" as I only need to draw it directly to a bitmap. Does anyone have any suggestions?
neo
neo
Post by neo » Tue Sep 21, 2010 6:11 pm
I resolved the issue by creating an invisible TForm and drawing the TChart on that.
Thanks for everyones help.
Cheers
Post by Yeray » Wed Sep 22, 2010 7:25 am
Hi neo,
Thanks for sharing your solution!
I glad to hear you found it.
