TeeChart 8 + Multitouch Gesture
lolo31
Post by lolo31 » Tue Sep 07, 2010 9:31 am
I'm trying to use Gesture with Teechart 8.
Why the OnGesture event is not published.
When I create a component derived from TeeChart and published this event, it never raises.
So, I use the OnGesture event of the form.
I'm trying to zoom out/in with a pinch out/in gesture but ZoomPercent method always zoom out (even if PercentZoom is greater than 100%)
So, have you some code to implement a right zoom in/out with this gesture ?
Laurent.
lolo31
Re: TeeChart 8 + Multitouch Gesture
Post by lolo31 » Wed Sep 08, 2010 7:12 am
I understand the problem with the PercentZoom: If it's greater than 200, it makes a zoom out !
So, if it's equal to 150, it makes a huge zoom in !
Here is the code that makes pinch in/out usable :
procedure TForm1.FormGesture(Sender: TObject; const EventInfo: TGestureEventInfo; var Handled: Boolean);
case EventInfo.GestureID of
igiZoom: begin
if gfBegin in EventInfo.Flags then
FDistance := EventInfo.Distance
else if (EventInfo.Distance > FDistance) then
Chart1.ZoomPercent(100.5)
Chart1.ZoomPercent(99.5)
Do you plan a better multitouch gesture support in a next release ?
Laurent.
Post by Yeray » Wed Sep 08, 2010 2:34 pm
Hi Laurent,
I've added it to the wish list to be implemented in future releases (TV52015142)
