Request to expose IsValidDataSource for override
Liang
Post by Liang » Wed Aug 25, 2010 3:16 pm
Hello
I am now using BDS2006 C++Builder, with TeeChart 2010 Pro.
Currently, according to example, I need to define a new class derived from TDBChart with IsValidDataSource overridden to have some dataset hidden.
This is very complicated, according to demo, all must be programmed to be created run-time, and many coding work. And also I have headache for cross-unit datasets namespace problems.
Is it possible for TDBChart to expose this IsValidDataSource, so I can do in such a way to have an easy override?
1. Create a new event called OnValidDataSource to pass parameters out for user to further changing -->preferred
or
2. Directly expose the function address of IsValidDataSource for overriding.-->not perferred.
Re: Request to expose IsValidDataSource for override
Post by Yeray » Fri Aug 27, 2010 1:49 pm
Hi Liang,
I've added your request to the wish list to be studied for inclusion in next releases (TV52015116).
Liang
Post by Liang » Wed Sep 15, 2010 1:14 pm
Hello
I have implemented such exposure of OnValidDataSource event. And it works fine.
Now I can make my software more clean, with only desired DataSet shown to user at run-time.
I would like to contribute my modification on DBChart.pas to you. Please check it:
line 48
  TValidDataSourceEvent=Procedure(Sender:TCustomDBChart; ASeries:TChartSeries; AComponent:TComponent;
    var Valid:Boolean) of object;
line 57:
    FOnValidDataSource:TValidDataSourceEvent;
line 91:
    property OnValidDataSource:TValidDataSourceEvent read FOnValidDataSource
                                                 write FOnValidDataSource;
line 104:
    property OnValidDataSource;
line 488:
Function TCustomDBChart.IsValidDataSource(ASeries:TChartSeries; AComponent:TComponent):Boolean;
  BoolValue:Boolean;
Begin
  BoolValue:=inherited IsValidDataSource(ASeries,AComponent);
  if not BoolValue then BoolValue:=(AComponent is TDataSet) or (AComponent is TDataSource);
  if Assigned(FOnValidDataSource) then
    FOnValidDataSource(Self,ASeries,AComponent,BoolValue);
  Result:=BoolValue;
Post by Narcís » Fri Sep 17, 2010 9:01 am
Hello Liang,
Thank you very much for your contribution. We will analyse it and get back to you as soon as possible.
Post by Narcís » Fri Sep 17, 2010 11:17 am
Hi Liang,
I think you can already override IsValidDataSource as in the examples in this thread. The projects Jørgen posted already derive a class from TDBChart and override IsValidDataSource method. Does this fit your needs?
Liang
Post by Liang » Sun Sep 19, 2010 2:31 am
Hello
I think mine is different, and prefer my way.
My solution is to expose the event of ValildDataSource on the TDBChart level, so I can directly in my source code, catch this event from the TDBChart component, and override the result by user as
 void __fastcall TScriptFrame::ResultDBChartValidDatasource(
      TCustomDBChart *Sender, TChartSeries *ASeries, TComponent *AComponent,
      bool &Valid)
  Valid=(AComponent==DataSource->DataSet);
So the freedom is at the user side.
Post by Narcís » Wed Sep 22, 2010 8:02 am
Hi Liang,
Ok, we implemented this for next maintenance release.
