using WaterfallSeries and setting the property Inverted for the Depth Axis results in a steady access violation.
Any suggestion to fix the problem?
Best regards
Heinz
P.S.: I'm working with version 8.04
WaterfallSeries - Inverted Depth Axis
Re: WaterfallSeries - Inverted Depth Axis
Hi Heinz,
I could reproduce it so I've added it to the defect list to be fixed in future releases (TV52015102).
I'm afraid I can't think on a workaround for this.
I tried it with 8.07 and it seems to behave the same.
Best regards
Heinz
Best regards
Heinz
Hi Heinz,
Could you please tell us in what IDE are you getting the problem? I can't reproduce it with the v8.07 neither in Delphi 7 or RAD Studio 2010.
I did a countercheck: I only put a TChart-component onto a form, created a Waterfall-series and filled it with random values. And it works - even with 8.04 and Delphi7 !
Then I exported the tee-file ( the attached file: WFTest.tee) and opened it with TeeChart-Office 3.0.
Now I changed the Depth-Axis property to inverted .......and as soon as the mouse is moved over the chart the exception occurs.
Best regards
Heinz
Best regards
Heinz
- WFTest.zip
- WFTest.tee
- (82.24 KiB) Downloaded 386 times
Hi Heinz,
Thank you for the information. I've updated the issue information.
