VCL 2010 Breaking Changes?
Steve Maughan
Post by Steve Maughan » Tue Aug 03, 2010 12:11 pm
Hi, I've just upgraded to 2010 and have encountered quite a few problems in my application with the changing behavior associated with the new event OnClickPointer (and the changing behavior of OnClickSeries). Is there a list of breaking changes? Furthermore, is there a list of workarounds to accommodate the new functionality?
Best regards,
Steve
Re: VCL 2010 Breaking Changes?
Post by Yeray » Tue Aug 03, 2010 3:33 pm
Hi Steve,
There are some recent issues related to these events already in the list of bugs and "wishes" or improvements. Could you please explain them in detail so we can tell you if they are listed or not?
If they are already known, we will tell you the ticket number of the issue so you can search for it in the release.txt of the next maintenance releases. If it's a new problem, we'll add it and try to give you a workaround.
However, before this, I'd recommend you to search for the same or similar problems here in this support forums.
I think you've already done it here ;)
We'll answer you there asap.
Steve Maughan
Post by Steve Maughan » Tue Aug 03, 2010 4:14 pm
Yes I had a look in the forums and the the issue seemed related to one already posted but somewhat different. I also created the demo project in my other post. This is really a big issue for me - I'm surprise more users aren't affected. A quick fix (via a software patch since I'ma source code client), would be appreciated. Also a time frame for the fix would be appreciated as I need to make the decision to either wait for the patch or go back to version 8.
You help is appreciated!
Steve Maughan
Post by Yeray » Thu Aug 05, 2010 3:55 pm
Hi Steve,
I've answered the issue there
