Problem with Axislabel
FHG_AST
Post by FHG_AST » Tue Jul 20, 2010 9:03 am
Hi@All
I have build a unit conversion componenten that changes the labels of the chartaxis so that I can switch from meters to millimeters or feet.
I do this unit conversion in the GetAxisLabel function like this
Procedure TUnitconv.GetAxisLabel(Sender: TChartAxis; Series: TChartseries; ValueIndex: Integer; var LabelText: string);
var FUCF:double;
    DS:Toracledataset;
    SN:TChartAxis;
    Tag:integer;
inherited;
    SN:=Sender;
    try
    if assigned(Series) then
     DS:=Toracledataset(Series.DataSource);
     //Hier irgendwie herausbekommen ob es die vertikale oder die horizontale achse ist
     if (Series.GetVertAxis =SN) then
      if DS.FieldByName(Series.YValues.ValueSource).Tag>0 then
      //get the unit conversion factor
      FUCF:=Funits[Funititems[Toracledataset(Series.datasource).FieldByName(Series.YValues.ValueSource).Tag,2]].CFaktor;
      Labeltext := Floattostr(strtofloat(Labeltext)/FUCF); //calculate the new label
     if (Series.GetHorizAxis =SN) then
      if DS.FieldByName(Series.xValues.ValueSource).Tag>0 then
      FUCF:=Funits[Funititems[Toracledataset(Series.datasource).FieldByName(Series.XValues.ValueSource).Tag,2]].CFaktor;
      Labeltext := Floattostr(strtofloat(Labeltext)/FUCF);//calculate the new label
    Except
My problem is that this only works if
TChartseries(parent.Components[j]).ParentChart[sindex].GetVertAxis.LabelStyle:=talText;
Then the unit conversion works well but the ditance between the axis labels is not equal.
If I switch to
TChartseries(parent.Components[j]).ParentChart[sindex].GetVertAxis.LabelStyle:=talValue;
then the distance of the labels is equal bit then the unit isn't converted.
Is there a way to get the unit conversion with equal label distances run?
Re: Problem with Axislabel
Post by Yeray » Tue Jul 20, 2010 3:04 pm
Hi FHG_AST,
With talText, an axis label will be drawn for each point in the series (in fact, in the first series linked to that axis) that has label. So this LabelStyle isn't thought to prevent labels overlap or to be drawn in equal distances.
However, you could use custom labels like in the demo at All features/Welcome !/Axes/Labels/Custom Labels. You can clear all the labels from the left axis and add the labels you wish.
FHG_AST
Post by FHG_AST » Wed Jul 21, 2010 6:42 am
Is there another posibility to change the labels on the left axis between the value is read from the dataset and the display on the screen wwith the use of talValue?
Post by Yeray » Wed Jul 21, 2010 11:01 am
Hi FHG_AST,
Yes, you can use OnGetAxisLabel event to change the labels. For example:
var i: Integer;
    tmp: Double;
  Chart1.View3D:=false;
  Chart1.MarginLeft:=15;
  tmp:=Random(1000);
  Series1.Add(tmp, FloatToStr(tmp));
  for i:=1 to 99 do
    tmp:=Series1.YValue[i-1] + Random(10) - 5;
  Chart1.Axes.Left.LabelStyle:=talValue;
procedure TForm1.Chart1GetAxisLabel(Sender: TChartAxis; Series: TChartSeries;
  if (Sender = Chart1.Axes.Left) then
    LabelText:=LabelText + ' -> ' + FormatFloat('#,##0.###',StrToFloat(LabelText)*1000)
