Runtime RoundRectangle Problem
HMArnold
Post by HMArnold » Thu Jun 17, 2010 3:35 pm
When I run the following Delphi code :
procedure TGraphForm.Display(Sender: TObject);
var Series : TChartShape;
Chart.SeriesList.Clear;
Series := Chart.AddSeries(TChartShape) as TChartShape;
Series.Style := chasRectangle; Series.RoundRectangle := true;
Series.Text.Add('Test 1');
Series.Alignment := taLeftJustify; Series.VertAlign := vaTop;
Series.X0 := 100; Series.X1 := 200; Series.Y0 := 150; Series.Y1 := 250; Series.Title := 'Test 1';
The rectangles show up fine, but the corners are always square.
Taking out the "Series.RoundRectangle := true;" causes the legend item to show up with rounded corners, but not the shape itself
The rounded corners work fine when set at design-time, but I have a variable number of rectangles, so I have to be able to define on-the-fly.
Any suggestions appreciated
HMA
Re: Runtime RoundRectangle Problem
Post by Yeray » Fri Jun 18, 2010 3:17 pm
Hi HMA,
Yes, I've seen that the RoundRectangle from TChartShape series doesn't seem to work in 3D. I've added it to the defect list to be fixed in future releases (TV52014984).
