TreeMap - Issue with Marks Tool Tips
TimeAcct
Post by TimeAcct » Tue Jun 01, 2010 6:06 pm
When I implemented the MarksToolTips - it works great for Labels - but the Value and Percents are not correct.
They seem to be based on the Special Value - not the actual value assigned to the series elements
Let me know if you need a sample
Bradley MacDonald
brad_AT_timeacct_DOT_com
Re: TreeMap - Issue with Marks Tool Tips
Post by Yeray » Wed Jun 02, 2010 3:22 pm
Hi Bradley,
Note that the TreeMap series stores the "values" in the XValue array and the relationship in the YValue array.
So, to make the marks show the "value" you could do:
ChartTool1.Style:=smsXValue;
Regarding the smsPercentage, you are right, it doesn't seem to work as expected. I've added it to the wish list to be implemented in future releases (TV52014927).
In the meanwhile, note that the marks can be customized with the OnGetSeriesMark event. Here it is an example:
  private
    { Private declarations }
      procedure Series1GetMarkText(Sender: TChartSeries; ValueIndex: Integer; var MarkText: String);
uses TeeOrgSeries, TeeTreeMapSeries, TeeTools;
var treemap1: TTreeMapSeries;
    markstip1: TMarksTipTool;
  treemap1:=Chart1.AddSeries(TTreeMapSeries.Create(self)) as TTreeMapSeries;
  markstip1:=Chart1.Tools.Add(TMarksTipTool.Create(self)) as TMarksTipTool;
  treemap1.Add(100,'A',-1);
  treemap1.Add(75,'B',0);
  treemap1.Add(25,'C',0);
  treemap1.OnGetMarkText:=Series1GetMarkText;
  markstip1.Style:=smsPercent;
procedure TForm1.Series1GetMarkText(Sender: TChartSeries; ValueIndex: Integer; var MarkText: String);
var i, tmpCount: Integer;
    tmpTotal: Double;
  tmpCount:=0;
  tmpTotal:=0;
  for i:=0 to Sender.Count-1 do
    if Sender.YValue[i]=Sender.YValue[ValueIndex] then
      tmpTotal:=tmpTotal+Sender.XValue[i];
      tmpCount:=tmpCount+1;
  MarkText:=FormatFloat('#,##%',Sender.XValue[ValueIndex]*100/tmpTotal);
TimeAcct
Post by TimeAcct » Wed Jun 02, 2010 3:25 pm
Yeray,
Thank you very much! I must say the support in these forums is outstanding.
In the last few days you have answered all my questions - and even sent source code - and a patch.
Very impressive!
Bradley MacDonald
Post by Yeray » Wed Jun 02, 2010 3:33 pm
Hi Bradley,
I'm glad to see you satisfied with it!
And thanks for the praises! :oops:
