Support for transparent series in exports
mpv
Post by mpv » Tue May 25, 2010 7:54 am
I have read some conflicting posts on the status of exporting transparant series in TeeChart.
In my experience, only bmp export works OK now. As this is not a very useful format, I was hoping that png would work as well, and some messages in your forum state that it works for png exports (in 8.03 to be specific). In my experience, it does however NOT work in 8.06 and 8.07
I worked around the problem by exporting to bmp and then using the built in png support in Delphi 2009 to convert to png, but this should not be necessary.
Any ideas ?
Regards, Matt
Re: Support for transparent series in exports
Post by Yeray » Tue May 25, 2010 4:20 pm
Hi Matt,
This can be done in a similar way than the descibed here. For PNG:
uses Series, TeePNG, TeeBMPOptions;
var i: Integer;
  for i:=0 to 2 do
    with Chart1.AddSeries(TAreaSeries.Create(self)) as TAreaSeries do
      FillSampleValues();
      MultiArea:=maStacked;
      Transparency:=50;
      AreaLinesPen.Visible:=false;
  tmpPNG: TPNGExportFormat;
  MetaCanvas: TMetafileCanvas;
  Bitmap: TBMPExportFormat;
  tmpPNG := TPNGExportFormat.Create;
  tmpPNG.Panel:=Chart1;
  try
    Bitmap:= TBMPExportFormat.Create;
    Bitmap.Panel:=Chart1;
    try
      tmpPNG.Height := Bitmap.Height;
      tmpPNG.Width  := Bitmap.Width;
      tmpPNG.Bitmap.Canvas.Draw(0,0,Bitmap.Bitmap(TBMPOptions.Create(self)));
      tmpPNG.SaveToFile('C:\tmp\test.png');
    finally
      Bitmap.Free;
  finally
    tmpPNG.Free;
mpv
Post by mpv » Wed May 26, 2010 10:07 am
Thanks Yeray,
That works fine! (after losing the (TBMPOptions.Create(self)) part, no problem)
This allows me to use older versions of Delphi as well, as I still use Delphi 6 for our main project.
Also saves handling another temporary file.
Regards, Matt
Post by Yeray » Wed May 26, 2010 1:09 pm
Hi Matt,
I'm glad to head that!
