TeeChart 8.07 VCL TChart Legend issues
Collinor
Post by Collinor » Mon May 10, 2010 6:59 am
In one of our charts we have set the legend's CustomPosition property to True. We experienced to following problems:
1. When using TChart's OnGetLegendPos event, the legend entry's customised position applies to the legend entry's text, but not to the legend entry's symbol and checkbox.
2. When using TChart's OnGetLegendRect event to widen the legend's dimensions, the NumCols property of the TChart's Legend is still computed using the TCharts ChartRect rectangle, so a line in the legend is wrapped earlier than expected.
3. When using TChart's OnGetLegendRect event to widen the legend's dimensions, we have to explicitly set the TChart's MarginTop property to avoid overlapping of legend and chart.
Re: TeeChart 8.07 VCL TChart Legend issues
Post by Yeray » Tue May 11, 2010 11:41 am
Hi Collinor,
Collinor wrote:1. When using TChart's OnGetLegendPos event, the legend entry's customised position applies to the legend entry's text, but not to the legend entry's symbol and checkbox.
In the following example I can see both the symbols and the text moved. The symbols seem to respond only to the Y displacement while the text is responding to both X and Y displacement.
uses series;
var i: Integer;
  Chart1.View3D:=false;
  for i:=0 to 3 do
    Chart1.AddSeries(TLineSeries.Create(self));
    Chart1[i].FillSampleValues;
  Chart1.Legend.Alignment:=laTop;
  Chart1.Draw;
  Chart1.Legend.CustomPosition:=true;
  Chart1.MarginTop:=15;
procedure TForm1.Chart1GetLegendPos(Sender: TCustomChart; Index: Integer; var X,
  Y, XColor: Integer);
  Y:=Y-20;
  X:=X-200;
Could you please confirm that this is what you are noticing?
Collinor wrote:2. When using TChart's OnGetLegendRect event to widen the legend's dimensions, the NumCols property of the TChart's Legend is still computed using the TCharts ChartRect rectangle, so a line in the legend is wrapped earlier than expected.
I'm not sure to understand your problem here. Please, take a look at the following example and modify it so we can reproduce the problem or indicate us what would you expect to obtain on it:
uses series;
var i: Integer;
  for i:=0 to 10 do
  Chart1.Draw;
  Chart1.MarginTop:=20;
procedure TForm1.Chart1GetLegendRect(Sender: TCustomChart; var Rect: TRect);
  Rect.Right:=Rect.Right-80;
  Chart1.Title.Text.Text:='NumCols: ' + IntToStr(Chart1.Legend.NumCols);
Collinor wrote:3. When using TChart's OnGetLegendRect event to widen the legend's dimensions, we have to explicitly set the TChart's MarginTop property to avoid overlapping of legend and chart.
I think this is an expected behaviour. Once you set the legend CustomPosition to true, the chart fits all the space available and you have to customize the legend position and move the chart according to this custom position (or not if you would like the legend to be inside the chart).
Collinor
Post by Collinor » Fri May 14, 2010 1:08 pm
Yeray wrote:Hi Collinor,
uses series;
var i: Integer;
  for i:=0 to 3 do
  Chart1.Draw;
  Y:=Y-20;
  X:=X-200;
Yes, that's what I'am noticing.
Here's my code. The legend must be much wider than the chart to see what's going on. When running my code you will notice, that the items per legend line are computed according to the chart's width, not the legend's width.
uses series;
var i: Integer;
  for i:=0 to 10 do
  Chart1.Draw;
  Chart1.Top  := 0;
  Chart1.Left := 0;
  Chart1.MarginTop :=20;
  Chart1.MarginLeft  := 20;
  Chart1.MarginRight := 20;
  ClientWidth  := Chart1.Width;
  ClientHeight := Chart1.Height;
  Rect.Top  := 10;
  Rect.Left := 10;
  Rect.Right:= Chart1.Width-10;
Ok.
Post by Yeray » Fri May 14, 2010 2:14 pm
Hi Collinor,
1.
Collinor wrote:Yes, that's what I'am noticing.
Ok, thanks for reporting it. I've added it to the defect list to be fixed in future releases (TV52014883).
2.
Collinor wrote:Here's my code. The legend must be much wider than the chart to see what's going on. When running my code you will notice, that the items per legend line are computed according to the chart's width, not the legend's width.
I could reproduce the issue here with your code so I've added it to the wish list to be revised in future releases (TV52014884).
In the meanwhile, I think you could calculate manually the NumCols and overwrite the value so that the legend will show as columns as you've calculated:
var PixelsInRow: Integer;
  Rect.Top  := 10;
  Rect.Left := 10;
  Chart1.Legend.NumCols:=1;
  PixelsInRow:=Chart1.Canvas.TextWidth(Chart1[0].ToString);
  while ((Chart1.Legend.NumCols < Chart1.SeriesCount) and ((PixelsInRow + Chart1.Canvas.TextWidth(Chart1[Chart1.Legend.NumCols].ToString) + Chart1.Legend.Symbol.Width - 9) < (Rect.Right - Rect.Left))) do
    PixelsInRow:=PixelsInRow + Chart1.Canvas.TextWidth(Chart1[Chart1.Legend.NumCols].ToString) + Chart1.Legend.Symbol.Width - 9;
    Chart1.Legend.NumCols:=Chart1.Legend.NumCols+1;
