TeeChart Bar
jangbu
TeeChart Bar
Post by jangbu » Tue May 04, 2010 1:15 pm
at runtime the bars appear more thin as at designe time and the space between the bars is much to big. Don't know the properties to change it at designtime. Why the chart appears at design time different to run time?
Thanks for answering
jangbu
Re: TeeChart Bar
Post by Yeray » Tue May 04, 2010 2:54 pm
Hi jangbu,
I can't see this effect with TeeChart v2010. I followed this steps:
- Create a new Delphi application.
- Drop Chart into the form.
- Double-click on the chart to open the editor at design time.
- Add a BarSeries.
- Go to Series/DataSource tab and select "Manual" in the combobox.
- Close the editor and run the application.
Could you add more steps to the list above so we can reproduce the issue here?
jangbu
Re: TeeChart Bar
Post by jangbu » Tue May 04, 2010 3:30 pm
Sorry Yeray,
problem is fixed. The first 2 lines below have been the reason for the trouble while runtime.
Chart1.RemoveAllSeries; // now removed
Chart1.AddSeries(TBarSeries); // now removed
Chart1[0].Clear;
Chart1[0].Add(value,'Test',clRed);
Thanks for effort
jangu
Re: TeeChart Bar
Post by Yeray » Tue May 04, 2010 3:48 pm
Hi jangu,
I'm glad to see you've found the solution!
