Teechart 8 and Intraweb 10 with Delphi 2010
Bruce
Post by Bruce » Mon May 03, 2010 5:58 pm
I have just bought Delphi 2010 and need to use Teechart (8.07) with Intraweb 10.0.23. I have created a IW100TeeChartPro8_140.dpk file, based on one I used to use in BDS2006. The required compiled packages in this are DclTee814.dcp, and Intraweb_100_100.dcp plus inet.dcp, rtl.dcp, vcl.dcp, vclimg.dcp and vclx.dcp. When I try to compile, I get an error message that vcljp is required but as I understand it this is replaced by vclimg in Delphi 2010. What is required to compile things to get TeeChart working with Intraweb 10 in Delphi 2010.
Bruce
Re: Teechart 8 and Intraweb 10 with Delphi 2010
Post by Yeray » Tue May 04, 2010 2:26 pm
Hi Bruce,
So changing the unit in the requires list has solved the problem, isn't it?
If you confirm it, we'll prepare the IW100TeeChartPro8_140.dpk package as you've done and it will be given with the installer.
