RotateInertia
X-ray
RotateInertia
Post by X-ray » Mon May 03, 2010 8:18 am
I just tried to make use of the RotateInertia property ofTTeeCommander in TChart 2010.
I had expected that setting a value greater than zero has a certain effect when rotating
a chart but I can't see any effect. Do I miss something?
Unfortunately this isn't descibed in the TeeChart help file and I also can't find any example source code.
best regards,
X-ray
Re: RotateInertia
Post by Yeray » Mon May 03, 2010 3:31 pm
Hi X-Ray,
I've seen that the Inertia property is working only with the TRotationTool. I've added the possibility to make it work also for the TTeeCommander Rotation button to the wish list to be implemented in future releases (TV52014845).
