Stacked Area--again
TestAlways
Stacked Area--again
Post by TestAlways » Thu Apr 29, 2010 3:20 pm
I thought I had this figured out but alas, I got put it in my deployment app and it not working right.
I created a demo that shows 3 stacked area series, but I cannot figure out what I am doing wrong.
Here is a screen shot:
I need the empty space to be removed--I've spent hours on this trying to figure out what I am doing wrong.
Demo attached.
Ed Dressel
Stack Area 2.zip
(7.24 KiB) Downloaded 527 times
Re: Stacked Area--again
Post by Narcís » Fri Apr 30, 2010 4:15 pm
Hi Ed,
I'm afraid the problem here is similar to what was discussed here. Second series has one point more than others. Adding a TTeeCommander component to your application and going to the Data tab you'll see there's a repeated X value by the end of the series.
TestAlways
Post by TestAlways » Fri Apr 30, 2010 5:24 pm
Thanks. I was using modified code provided in a previous post (http://www.teechart.net/support/viewtop ... =3&t=10352).
I modified the original code, and applied the mod to my code. This fixed it. Please let me know if this is correct.
Ed Dressel
procedure TForm46.UpdateChart;
  I: Integer;
  J: Integer;
  lValue: Double;
  lSrs: TChartSeries;
  Stairs: array of TPoint; //X values will store the series index, and Y values will store the value index of the stairs
  Chart1.FreeAllSeries;
  SetLength(Stairs,0);
  for I := 0 to spnNumSeries.Value-1 do
    lSrs := CreateSeries;
    for J := 0 to spnNumPoints.Value-1 do
      lValue := GetValue(I, J);
      if lValue > 0 then
        lSrs.AddXY(J, lValue)
        lSrs.AddNullXY(J, lValue);
      if (lValue > 0) and (GetValue(I, J + 1) = 0) then
        lSrs.AddNullXY(J, 0);
        SetLength(Stairs,Length(Stairs)+1);
        Stairs[Length(Stairs)-1] := Point(I,J);
  for I := 0 to Length(Stairs)-1 do
    //for J := Stairs[I].X+1 to spnNumSeries.Value-1 do  // <------ REMOVED
    for J := 0 to spnNumSeries.Value-1 do   // <------ ADDED
      if J <> Stairs[I].X then   // <------ ADDED
        Chart1[J].AddXY(Stairs[I].Y, Chart1[J].YValue[Stairs[I].Y]);
Post by Narcís » Tue May 04, 2010 1:49 pm
Hi Ed,
Yes, changing code below in your example works fine for me here.
    for I := Length(Stairs)-1 downto 0 do
      for J := 0 to Chart1.SeriesCount-1 do   // <------ ADDED
          Chart1[J].AddXY(lSrs.XValue[Stairs[I].Y], lSrs.YValue[Stairs[I].Y]);
