How to avoid overlapping when checking Series-Point-Visible
wwp3321
Post by wwp3321 » Fri Mar 12, 2010 4:52 am
How to avoid overlapping when checking "Series-Point-Visible"?
"Marks" can be drawed every several points by setting the "Series--Marks--Draw every:".
Does "Point" have the any similar setting?
wwp3321
Re: How to avoid overlapping when checking Series-Point-Visible
Post by wwp3321 » Fri Mar 12, 2010 4:57 am
For Example:
1.I add 300 points to Series1.
2.Then I Check the "Series--Point---Visible".
There are so many points that points overlap each other.
So I want to show "Point" every several points to avoid overlapping.
Post by Yeray » Fri Mar 12, 2010 5:05 pm
Hi wwp3321,
If I understand well, you have a TLineSeries with pointer visible but too much values to show all that pointers so you would like to hide some of them. Here is how you could do it:
  private
    { Private declarations }
    function Series1GetPointerStyle(Sender: TChartSeries; ValueIndex: Integer): TSeriesPointerStyle;
uses series;
  Chart1.View3D:=false;
  Chart1.Legend.Visible:=false;
  with Chart1.AddSeries(TLineSeries.Create(self)) as TLineSeries do
    FillSampleValues(300);
    Pointer.Visible:=true;
    OnGetPointerStyle:=Series1GetPointerStyle;
function TForm1.Series1GetPointerStyle(Sender: TChartSeries; ValueIndex: Integer): TSeriesPointerStyle;
  if (ValueIndex mod 5 = 0) then Result:=psRectangle
  else Result:=psNothing;
wwp3321
Post by wwp3321 » Mon Mar 15, 2010 8:20 am
Thank you very much!
