johnnix
- Advanced
Post
by johnnix » Wed Mar 03, 2010 2:01 pm
I have a chart where I am using a custom axis. I use the OnClickAxis event and I cannot find any way to know that the axis I clicked is the custom Axis. Any help will be mostly appreciated
Kindest regards
Post
by Yeray » Wed Mar 03, 2010 4:54 pm
Hi johnnix,
The following code seems to work fine.
procedure TForm1.Chart1ClickAxis(Sender: TCustomChart; Axis: TChartAxis;
Button: TMouseButton; Shift: TShiftState; X, Y: Integer);
var i: Integer;
for i:=0 to Chart1.Axes.Count-1 do
if (Axis = Chart1.Axes[i]) then showmessage('clicked ' + IntToStr(i));
Could you please send us a simple example project we can run as-is to reproduce the problem here?
johnnix
- Advanced
Post
by johnnix » Thu Mar 04, 2010 5:56 am
Hello Yeray,
Maybe I was not clear enough
What I need to do is to identify that the axis I clicked is my custom axis. In the ClickAxis event I can check the Horizontal property of Axis to determine if it is the X or Y axis but there is no property like IsCustom!!! Is this clear?
johnnix
- Advanced
Post
by johnnix » Thu Mar 04, 2010 8:39 am
Just figured out that Axis.Index is -1 for default axis so by checking this value I know if I clicked on the custom Axis.
Post
by Yeray » Thu Mar 04, 2010 8:58 am
Hi johnnix,
I'm glad to see that you've found it! Thanks for sharing.
johnnix
- Advanced
Post
by johnnix » Thu Mar 04, 2010 9:02 am
Hello Yeray,
No problem, just consider adding a property e.g. IsCustom !!!
Post
by Yeray » Thu Mar 04, 2010 10:23 am
Hi jonnyx,
There is already a private IsCustom function but making it public needs some adjustments because right now it fails if you remove some of the default axes.
I've added it to the wish list to be revised for further releases (TV52014703).
