THighLowSeries with Gradient
davidnovo
Post by davidnovo » Tue Feb 23, 2010 11:27 am
I just noticed that you can fill the area between the high and low lines in a THighLow series. But it seems you can only fill it with a solid color. Is it possible to fill it with a gradient, such that the middle between the high-low is the darkest and as it approaches the high or the low it becomes lighter (or transitions to whatever the secondary gradient color is)?
Ideally there should be a few gradient options, left to right, right to left, top to bottom, bottom to top, center to outside, outside to center...
I will be happy with just center to outside :-)
If this series won't do it, is there another I can use. I have varying high-low Y values as I go across the X axis, so a horizontal bar won't work
Re: THighLowSeries with Gradient
Post by Yeray » Tue Feb 23, 2010 2:42 pm
Hi davidnovo,
The following seems to work fine here for THighLowSeries:
  Chart1.View3D:=false;
  Series1.FillSampleValues();
  with Series1.HighBrush do
    Style:=bsSolid;
    Gradient.Visible:=true;
    Gradient.StartColor:=clRed;
    Gradient.EndColor:=clYellow;
    Gradient.Direction:=gdTopBottom;
